No DVD Please insert Map DVD
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by robl45, Jan 16, 2018.
  1. robl45
    robl45 Member
    137
    Hello,
    I saw this message the other day and restarted the car and it went away, that was probably a week or so ago. Today it came back again and won't go away. I took the disc out of the dvd load under the seat and put it back in, but no matter what, it still says no dvd insert dvd. It also says checking DVD and then goes back to no DVD.
    Has anyone had this issue and know how to solve it?
    EDIT: Just went out to car, turned it on and it works again. Obviously I don't imagine it will keep working. Any ideas?
    #1 robl45, Jan 16, 2018
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    It sounds like you might have a bit of dust on the Laser, or the pickup. If you can, shoot a small burst of DRY air into the DVD reader and try to dislodge the dust. DO NOT tip a can of air so the liquid comes out, it could mess it even more than it is! On my Gen II I puled the cover off, made this task much easier, and it fixed my problem!
  3. robl45
    robl45 Member
    137
    So shoot compressed air into the dvd slot? What do you mean by take the cover off, you mean physically unscrew the unit from the floor and open it up like you would do for the reset button? I can do that if it makes it work better.
  4. KK6PD
    4,003
    946
    118
    Yes, car was powered off, I disconnected the unit, pulled it from the car, opened it up, cleaned it, worked fine after that! CD & DVD players were never designed to work for years in a filthy auto environment! Or you can have Toyota look at it, then they will probably try to stiff you with a new expensive unit!
    BTW, for what it's, I am a board level maintenance tech among other things, this is second nature to me!!
  5. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    I'm trying to pull the dvd player. It is a bitch to get at the screws. Do I have to remove the seat?
  6. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    You shouldn't have to, but you will need to move the seat all the way to the most rearward position. Gain access from the LH (US Driver's) door.
    kenoarto likes this.
