Correct solvent for adhesive removal?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Snoho3, Jan 13, 2018.
  1. Snoho3
    Snoho3 Junior Member
    Snohomish WA
    I
    just received my new Prime. I pulled off the yellow and white warning sticker on the cell phone charging tray on the center plastic console. Quite a bit of the adhesive was left behind. Question - what can I use to remove the remaining adhesive.seems like very tough stuff and I don’t want to damage the finish of the plastic.
    Thanks in advance for any suggestions!
  2. frodoz737
    frodoz737 Top Wrench
    4,694
    2,496
    33
    Citrisafe.
  3. ChapmanF
    18,076
    Funny, I have a bottle of something called citrasolv that's my usual go-to for stuff like that.
    Don't underestimate it, though. You might try it a little diluted first. It will soften some plastics, enough that you might leave marks if you are using a pointy tool or stiff brush, probably not if you just roll the goop off with your fingers or a paper towel. Rinse well as soon as you're done so it's not on there longer than necessary.
    -Chap
  4. Mendel Leisk
    41,327
    When I was researching how to remove wheel weight adhesive, this stuff was highly recommended:
    3M 38983 General Purpose Adhesive Remover
    Haven't followed through and tried it though.
  5. El Dobro
    El Dobro A Member
    7,088
    3,270
    Mineral spirits work for me.
  6. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
    WD-40 worked for me when removing packing tape adhesive from the plastic rear "bumper" when I had my 2010. Please do not ask why I had packing tape adhesive on the plastic rear "bumper." :whistle:
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Goo Gone is great stuff.
  8. cramer77
    cramer77 Junior Member
    22
    Markham Canada
    2018 Prius Prime
    Touring + Tech
    Agreed on the Goo Gone stuff. Dollarama had a small 2 oz bottle for $1.00 last time I was there.
  9. RRxing
    2,545
    1,821
    NEPA
    Used to use Goof Off - Don't know if it's still available, but worked great as well...
  10. Lee Jay
    5,850
    4,036
    Goof Off is not compatible with all plastics. It will attack and ruin some types.
  11. TinyTim
    TinyTim Active Member
    380
    234
    Seattle
    I use both goof off and goo gone. Both work fine on plastics. Don't use the professional strength liquid that comes in a paint thinner like bottle usually (non spray bottle) 6oz. That is the heavy duty stuff that takes everything off.
  12. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    What's fairly safe and mild and good is cigarette lighter fluid.
    The Goof Off I just got at Walmart has xylene and acetone...the acetone can be aggressive, and would not normally be found in lighter fluid, whereas the xylene is probably a typical lighter fluid component.
  13. padroo
    padroo Senior Member
    2,763
    2,252
    Rubbing alcohal is a safe try, it is on the safer end to try.
  14. Weasle543
    Weasle543 Member
    55
    Ohio
    peanut butter, wd-40, isopropyl alcohol
  15. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    I used it to remove paint protection film from the nose if my ole blizzard pearl PIP and it does what it's supposed to do.
    The right tool for the job IMHO even if it costs a bit more than the others.
