Side moldings
Discussion in 'Prime Accessories and Modifications' started by benagi, Dec 19, 2017.
  1. benagi
    benagi Active Member
    525
    280
    Utah
    Has anyone purchased side moldings for their Prime and installed them their self? Any place besides the dealership to purchase factory side moldings ? Are they hard to install and line up properly ? Thx, Ben
  2. ct89
    ct89 Active Member
    323
    266
    New England
    The ones on my prime came pre-installed but I did purchase and install the moldings on my Highlander. It was definitely a clean well, measure 5 times, stick once type of task.
    The moldings simply stick on the side of the car. Nothing more complicated than pealing the double-sided-tape and pressing onto the car...Assuming you have them in the right spot and the spot is clean so the tape holds.
    I used painters tape to outline the exact spot based in the instructions...That made it pretty straightforward to ensure they were placed in the right spot and allowed me to step back and look at the relative placement of both pieces on the side of the car before actually sticking them on.
    benagi and priuscatprimeguy like this.
  3. ct89
    ct89 Active Member
    323
    266
    New England
  4. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    I had a body shop install a set on my 2012 Prius I think it was like $50 labor. I had the dealer get and install them on my Prime as part of the sale.
  5. benagi
    525
    280
    Utah
    Ordered a set of side moldings for my Prime online and they have arrived with no instructions. Anyone know where I can get the installation instructions for a 2017 Prime?
  6. ct89
    ct89 Active Member
    323
    266
    New England
    A quick search found the following link:
    2017 Toyota Prius Prime Body Side Molding
    They link to the installation instructions I posted below. The instructions say 2016 Prius but the part numbers match the prime so I'm assuming the instructions ( and moldings) are common across both the regular Prius and the Prius prime.
  7. benagi
    525
    280
    Utah
    Thx for the link CT. I saw your 2016 gen 4 installation instructions yesterday. Just wanted to make sure I had the right measurements when installing. Especially since the Prime is a bit different than a Gen 4, I think.
    #7 benagi, Jan 18, 2018
  8. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    94
    Indiana and Nevada
    i did them myself...took about 2 hours...it would help if it was 55F or better (i did mine last summer)...have plenty of painters tape and a yard stick or meter stick /straightedge...(works better that way)...make sure the doors are very clean and dry...otherwise take your time and follow the enclosed instructions on measurements...on the prime they will not be perfectly level...there is a slope "down" back to front...
    benagi likes this.
  9. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    Here's mine. Installed by the dealer. Also had the trim below the rocker panels.
  10. JeffHastings
    JeffHastings Member
    223
    79
    Whippany, NJ
    I always recommend buying side moldings for any car, given realities of inconsiderate other drivers in parking situations. If it prevents a few dents and scratches, it's well worth the money. I had it on my Gen 3 Prius and have it on my current Avalon Hybrid. It's a must buy option for me.
  11. benagi
    525
    280
    Utah
    What did your dealer charge?
  12. Dudley1030
    200
    139
    Lawrence, KS
    I don't remember exactly. It was exactly what the online price was at Toyota.com. You can find it when you are putting together a car on their web site.
  13. ct89
    ct89 Active Member
    323
    266
    New England
    You can go to truecar.com and select the prius prime. After selecting the color, you can select "I want to build my own" in the bottom corner of the options window. From here you can see the MSRP and invoice of each option.
    Body side moldings show-up as MSRP=$209 and Invoice=$125
    They are a port installed option
  14. MagnetoBlue
    MagnetoBlue Junior Member
    74
    31
    Burbank, CA
    Is $50 a fair installation price from the dealership? I feel like they can do it for lower.
    benagi likes this.
  15. MagnetoBlue
    74
    31
    Burbank, CA
    Also, does anybody have a picture of the side molding AND aero side splitters on exterior color Magnetism Blue?
    I'm definitely getting the side molding but I'm not sure how black aero side splitters would look on Magnetism Blue.
  16. Dudley1030
    200
    139
    Lawrence, KS
    I think so.
    MagnetoBlue likes this.
  17. MagnetoBlue
    74
    31
    Burbank, CA
    I found Magnetism Blue with side moldings and aero side splitters! I already bought the moldings. I think I’m going to get the splitters as well!
    MrBugMan likes this.
