Questions about Prius Prime Options
Discussion in 'Prime Main Forum (2017-2022)' started by psoque, Aug 31, 2017.
  1. benagi
    benagi Active Member
    525
    280
    Utah
    Has anyone ordered a set of side moldings for their Prime? I see the Prius Shop wants $289. I have seen them on the net going for as lows as $176. Is this part# real PT9384716011. This would be for a magnetic gray Prius Prime. Thx, Ben
  2. ct89
    ct89 Active Member
    323
    266
    New England
  3. benagi
    525
    280
    Utah
  4. Prodigyplace
    12,712
    11,848
    Central Virginia
    @Elektroingenieur may be able to verify.
  5. ct89
    ct89 Active Member
    323
    266
    New England
    I'll try to piece together what I can offer.
    See: Side moldings | PriusChat for more details, I didn't order them for the prime but did for my Highlander, they were easy to install with care. The prime should be no different. This member did the install themselves and apparently had a similar experience.
    does anybody have a pic of a Prime with the side molding installed? | Page 2 | PriusChat
    They did come with detailed instructions Here's a link I found to instructions for a 2016 Prius. It will give you a feel for what the instructions are like. The part number is the same but I don't know if there were any changes for 2017.
    https://www.toyotapartsdeal.com/installation/my16%20prius%20body%20side%20molding-dio%20issb.pdf
    In post does anybody have a pic of a Prime with the side molding installed? | Page 3 | PriusChat I listed the part numbers for all colors and confirmed you have the correct part. The Magnetic Gray is the -11 version of the part PT938-47160
    I mentioned the lowest price I have seen was $160. Here's the specific reference to a Toyota dealer in my area that sells them.
    Molding, Body Side, Classic Silver Metallic - Toyota (PT938-47160-01)
    You probably need to order them on-line. In my experience these dealers will not sell the parts to you at this price if you show-up at the parts counter, you can only get these prices through on-line ordering. Maybe some will.
    Different dealerships offer different on-line discounts. Poke around at a few and you'll quickly find a set that offer the largest discounts. If you order from an out-of-state vendor, they will not charge you sales tax. These on-line dealerships have the lowest prices I have been able to find although the place I linked to for the instructions sells them for only $9 more if you prefer to avoid dealerships.
  6. benagi
    525
    280
    Utah
    Thx for the replies. This will help fulfill my order. One other question, what rear appliqué did most of you purchase? I see 2 main choices . I have to pickup 4 dogs everyday on the way home from work, and don’t want their feet scratching the back bumper.
    Also, why are the prices so much higher in the Prius shop in this forum?
  7. Prodigyplace
    12,712
    11,848
    Central Virginia
    I think the PriusChat Shop prices are Toyota list prices. I usually use Amazon marketplace or an online dealer.
    benagi likes this.
  8. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    FYI: If you use the charge mode while driving option, you will decrease your MPG quite a bit more than you'll probably get back just using the HV mode.
  9. Prodigyplace
    12,712
    11,848
    Central Virginia
    @bwilson4web seems to be a fan of using charge mode in certain situations, based on his testing.
    Dudley1030 likes this.
