Visual differences between radar emblem and standard?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by kromerok, Feb 19, 2018.
  1. kromerok
    kromerok Junior Member
    26
    Los Angeles
    2019 Prius Prime
    My Prius has that radar thing behind the emblem and I need to get it replaced along with the front bumper new its 500 and the bumper maybe 250. I found some used ones around that have the same color. My question is there a way to visually determine if the emblem is the correct one for the radar or not?
    Thanks
  2. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    RCO and padroo like this.
  3. krmcg
    2,592
    2,392
    Whittier, CA
    I have a used front bumper (Blizzard Pearl) that I can sell cheap.
    RCO likes this.
  4. kromerok
    26
    Los Angeles
    2019 Prius Prime
    kithmo likes this.
  5. pilotgrrl
    891
    1,797
    Chicagoan in TX
    No, Prii that have silver only emblems don't have the DRCC. in 2016, TSS-P was optional.
    RCO likes this.
  6. kromerok
    26
    Los Angeles
    2019 Prius Prime
    Im ideally looking for black does yours have the radar emblem?
  7. padroo
    padroo Senior Member
    2,763
    2,252
    What color is it without the radar?
  8. pilotgrrl
    891
    1,797
    Chicagoan in TX
  9. pilotgrrl
    891
    1,797
    Chicagoan in TX
    Without DRCC:
    With DRCC:
  10. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    Here is mine 2016 Prius three without DRCC
  11. krmcg
    2,592
    2,392
    Whittier, CA
    No. Empty hole.
  12. kromerok
    26
    Los Angeles
    2019 Prius Prime
    and the plot thickens
    Is it a regular Prius or one of the others prime, c, v
  13. Tideland Prius
    16,547
    Err.. all hybrids are black/blue so you can't use that as a differentiation.
    But using @randomwalk101 's picture above, you see the non-radar emblem is raised and is metal/chromed. Those DRCC will have a flat emblem like the 2nd photo @pilotgrrl had above.
    RCO, kithmo and Prodigyplace like this.
  14. Elektroingenieur
    2,515
    3,282
    Three Touring
    Besides the obvious physical difference @Tideland Prius kindly describes, both the radar-compatible (53141-47030) and non-radar (75310-47060) versions of the emblem assembly have the part number molded on the back, at least in the photos I’ve seen.
    Keep in mind, if the millimeter wave radar sensor assembly is replaced, you (or a dealer or repair shop) will need to do the beam axis adjustment procedure given in the Repair Manual. This requires a level surface with a 5 m × 6 m open area in front of the vehicle, a Toyota Techstream diagnostic system, and the Reflector C (09870-60040) and Stand Base (09870-60010) special service tools.
  15. kromerok
    26
    Los Angeles
    2019 Prius Prime
    Great the used bumper I bought came with the right emblem saved 500 right there and it was the original color :) and yes it did have the part number on the back.
    RCO and krmcg like this.
  16. Tideland Prius
    16,547
    o_O How many dealerships will have that reflector C and stand base?
    RCO likes this.
  17. Elektroingenieur
    2,515
    3,282
    Three Touring
    RCO and Tideland Prius like this.
  18. Tideland Prius
    16,547
    Ok good. I've been lucky in that people have been hitting my rear bumper and not my front bumper (with the IPA sensors and radar emblem).
    The IPA parks crooked sometimes due to the slightly misaligned rear bumper. Not looking forward to a Gen 4/Prime or similar that has ICS or BSM/RCTA. Any bumper damage may require a realignment or a new bumper.
    RCO likes this.
  19. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    But with the Gen 4's PCS there's less chance of damaging your bumper. ;)(y)
    RCO likes this.
  20. Tideland Prius
    16,547
    oh I wasn't talking about me. I haven't hit anything.
    Front left corner - supermarket (scratch)
    Front left corner (below the one above) - street parking. Caught the person looking at my bumper but I was in a forgiving mode so I let her go. She gave me her business card anyway in case I change my mind
    Rear left fender - hit and run (street). This is the one that put the rear bumper out of alignment
    Rear left corner - hit and run and left a decent dent in it. (car park)
    Rear right corner - Who knows.. probably supermarket
    RCO likes this.
