Actuator difficult bleed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ryan Harrington, Feb 27, 2018.
  1. Ryan Harrington
    Ryan Harrington Junior Member
    51
    Louisiana
    So I've heard that it can be difficult to bleed the system after replacing the actuator if the actuator gets air into it. I have been getting bubbles from the right rear and I've run a couple of quarts through the system. Anyone have experience with this?
  2. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    What have you used to try to bleed it? In Techstream (Mini-VCI is cheap version of it) you have separate bleed function to bleed the actuator.
  3. Ryan Harrington
    51
    Louisiana
    I bought one of the cheap cables online. The bleed function fails every time I've tried. So I tried the other method of putting jumper in the port and pumping the brakes and all. Found this method on priuschat. Unfortunately, it does not seem to be working well. I don't know what the problem is... I may call a mobile mechanic to come look at it with me
  4. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    1) You have a bad cable, and should have stopped there. Get a working cable and all will be well.
    You are using Techstream?
    You have the factory service manual?
    2) Maybe you should just throw in the towel and pay for professional service.
    valde3 likes this.
  5. Patrick Wong
    18,210
    6,510
    Do you have certain knowledge that air has entered the actuator, either because you replaced the actuator or you allowed the brake fluid in the reservoir to get too low?
    Is it possible that the air bubbles are resulting from air leaking into the wheel cylinder due to the loose bleed valve and a tiny gap between the valve threads and the wheel cylinder? If so, the continued presence of bubbling in the clear vinyl hose is not necessarily indicative of a problem...
    How well do the brakes work, after all bleed valves are tightened?
    Do any brake system warning lights remain on: ABS, VSC, BRAKE, or ((!)) ?
    Ryan Harrington likes this.
  6. Ryan Harrington
    51
    Louisiana
    I had all of those warning lights on. That's what led me to change the actuator assembly. It was a bit of a process, but I checked the codes and that appeared to be the problem. Now I'm seeing that the new part is leaking brake fluid somewhere. That may be my problem. I'm going to have to try to identify the leak while the actuator is running to see if it was my fault and something I can fix.
  7. Mattclay
    Mattclay New Member
    17
    Usa
