Gen 2 2004 tires slipping on acceleration
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Avengling, Mar 7, 2018.
  1. Avengling
    Avengling New Member
    Calimesa CA
    Tires slipping and/or chirping on acceleration at stop signs and in parking lots.
    I have a 2004 gen 2, I believe it's trim three but it was the only option allowed when I got it since there was a two year waiting list. (It has bluetoothe, keyless entry, six CD changer, and navigation but no moon roof). I've been the only owner of the vehicle and kept up on the maintnance.
    The tires are not bald and have been rotated regularly. I'm in Southern California so no extreme weather conditions like snow or heavy rain when this is happening. The check engine light came on once but was gone the next day when I got it looked at. I have a code reader that isnt throwing any codes. Any suggestions?
  2. Mendel Leisk
    41,474
    How old are the tires? Somewhere between 7~10 years is the limit, the rubber starts to crack/harden, tread bits flake off.
    What make/model too? Might be a factor.
    WilDavis likes this.
  3. Stevewoods
    Stevewoods Senior Member
    659
    1,135
    Seattle, WA
    if not mistaken, calimesa averages toward hot dry and windy. as mendel said, dry hardened rubber might be a factor.
  4. JC91006
    JC91006 Senior Member
    16,769
    8,567
    Maybe you just have a heavy foot? Or the pavement is a bit wet lately
  5. audiodave
    audiodave Active Member
    800
    272
    US
    Traction control does not let my tire spin. Goes off way to easy and is unsafe. Little bump in the road all it takes.
    edthefox5 likes this.
  6. ChapmanF
    18,220
    Traction control does let my tires spin, by a controlled amount. I'm driving a Gen 3, but this graph from Gen 2 shows it was designed that way then, too. It allows the driving wheel speed to stay a small, controlled amount faster than the actual vehicle speed:
    As for tires, I have always found them to start spinning more easily, way earlier than the rated tread life would suggest. I think I saw it explained in Consumer Reports a long time ago as a side-effect of the way the rubber is compounded; the grippiest formulation being in the outermost layer, which wears away down to a somewhat harder material. It's kind of disappointing, but I don't think I've ever owned a set of tires where I didn't notice that.
    -Chap
    uart and WilDavis like this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Traction control when launched on a G2 is very noticeable.Like audiodave says its really harsh and not a controlled amount if it happens when decelerating it scares the shite out of you.
    I doubt the OP has spinning tires as thats a big software no no on a G2 and really affects divisibility. Just ask anyone who has ever been stuck in a snowbank and tried to drive out with a G2.
    It may seem like she has spinning tires but maybe something else is slipping or chirping. A blown clutch dampener would do that and not invoke a code.
    The check engine light is probabaly the engine oil is very low on oil or almost out.
    uart, m.wynn, Avengling and 2 others like this.
  8. cyberpriusII
    1,155
    1,776
    Mars Hotel
    I was going to post something along the line of what edthefox5 said, but he beat me to it.
    The traction control is very noticeable, and mostly un-needed and mostly not helpful, unless you count being stranded with no power in the middle of an icy intersection helpful.
    Also good to note as mentioned by previous post, you need to check the oil as if you are on a mission from God. Thankfully, I have not had a problem, but countless people have.
    kris
    #8 cyberpriusII, Mar 7, 2018
  9. ChapmanF
    18,220
    The thing that usually scares the shite out of people when decelerating is the small gap between regen deactivation and ABS takeover if a small bump was hit during gentle braking. That is a definite thing of its own (and known back to Gen 1), but probably best, in the interest of new readers, not to conflate it with traction control.
    -Chap
    uart, R-P, SFO and 1 other person like this.
  10. padroo
    padroo Senior Member
    2,763
    2,252
    I didn't see a mention of the traction control warning light?
  11. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I noticed similar behaviour when my 2009 Gen II wore Michelin EnergySavers AS - they were ~60% worn, and I noticed the slippage and the VSC light flashing occasionally when on railway-crossings, speed-bumps ("Sleeping-Policemen" as they're called back in Blighty) or shortly after passing a hump-backed bridge at speed when the car becomes unweighted and the tyres tend to lose grip.
    I learned that Michelins have a tendency for the treads to outlast the side-walls, so I think the "hardening-rubber" suggestion might be the answer! Anyway, later, when I shopped around for a set of summers to replace them, I found that the Michelins couldn't be found in my size, so I changed brands and have not noticed any slippage since! However, as they always say, YMMV! ;)
    Avengling likes this.
  12. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Are these the original tires?
  13. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    I’m in California too, noticed the same, especially on cooler moist mornings. Both with my ‘72 Cougar 411 cu inches and my 05 Prius. It’s less with a new set of Bridgestone Ecopia than with the old set. Acceleration torque while cornering can be extreme and the traction control would notice it and reduce power to the drive wheels. I don’t have any trouble waiting to apply the torque until I’m past the crosswalks and the battery doesn’t mind delivering it either.
    iPhone ?
  14. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Exactly. The car would throw a Vsc nag instantly every time A tire spins at an independent speed.
    Very noticeable. Which makes me think whatever it is the car cannot monitor it.
  15. Avengling
    Calimesa CA
    No the car has had many sets of tires, it had about 150,000 miles on it. Different brands too and I e never had this problem before.
  16. Avengling
    Calimesa CA
    The traction light isn't coming on when this happens.
  17. Avengling
    Calimesa CA
    The traction warning light is not flashing when this happens.
  18. Avengling
    Calimesa CA
    The tires are three years old and I have had this make of tire on the car in the past without this problem occurring
  19. Avengling
    Calimesa CA
    If it was a different issue like this how would I be able to confirm it? Can you link a video or article?
  20. Patrick Wong
    18,210
    6,510
    What is the current tread depth of the front tires, and what tire inflation pressure do you use?
    Paul Schenck and kenoarto like this.
