Home made battery back for charging?
Discussion in 'Prime Main Forum (2017-2022)' started by Piwacet, Jul 17, 2017.
  1. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    The one place I visited in CA was Huntington Beach back in the 70's. It was awesome!(y):D
    HPrimeAdvanced, bisco and joachimz like this.
  2. Prodigyplace
    12,682
    11,833
    Central Virginia
    Link or it didn't happen. :D
    HPrimeAdvanced likes this.
  3. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Yewee The Flying Cat, 1st video!
    She used to do this repeatedly when we lived in Huntington Beach apartment!!
  4. TDR Marine Engineer
    TDR Marine Engineer Junior Member
    35
    Portable generator would cost more than just using the chg mode.
  5. CharlesH
    2,797
    1,165
    Roseville, CA
    Yes, it is hard to imagine a scenario for using a portable gasoline generator that would be anywhere near as efficient as using the gasoline engine in the PRIME in CHG mode. And even then, it is usually better to just use the gasoline engine to directly move the car in HV mode rather than incurring charging losses.
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Let’s see, Condo, yours from walls in right? So who owns, uses shared parking? Get with that owner and share all costs. Is 110V available? X 2 = 220 V, a L2 charger installed = 2.5 hours to full charge. Rent it out to other interested party’s. It all can be done. Even if you have to hire an electrician. If not the bldg your living in, perhaps a neighbors. Look for EV/ Hybrid cars around you.
  7. Andyprius1
    2,327
    859
    Cool CA
  8. Andyprius1
    2,327
    859
    Cool CA
    Try and convince the owner of its advantages to him. If there’s a Dryer plug around it’s easy to extend that to a charger and then plug in. L2 Charger cost $500 or less, delivered tomorrow at Amazon. Upon move out share cost with owner or take your charger with you.
  9. Andyprius1
    2,327
    859
    Cool CA
    Give the owner a test drive in your car, tell him you get 100 mpg!
