Black Hybrid Toyota Emblem
Discussion in 'Prime Accessories and Modifications' started by PHV PLS, Mar 15, 2018.
  1. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    I bought this little jewel on eBay. Waited 2 weeks and doesn’t fit on the back.. What a bummer!
    Time to plastic dip!
  2. Tideland Prius
    16,230
    :( Was it for a different Prius generation?
  3. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    Said it was for the Prime :cry: They even had pics of it on a Prime. First thing i checked was for what generation
    came from thailand so shipping took forever :cry:
  4. Tideland Prius
    16,230
    I don't think the Prime is sold in Thailand. The problem with overseas products is that they just assume and don't bother cross-checking.
  5. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    True! I mean I paid 10USD for it! I’ll just save it for now untill I can think of something cool to do with it :eek:
  6. SR-71
    SR-71 Member
    97
    108
    NC
    Does your Prius have the Radar Following option? If so, you may want to think twice before a cover over that emblem, as I understand it, that's where the radar signal gets emitted.
  7. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    Ooh this is for the back emblem. I dont believe it has a radar. The front I’m going to plasti dip mines with a 2 light coats I’ll jist plasti dip the back one :eek:
  8. citiprius
    citiprius Active Member
    241
    238
    51
    2018 Prius Prime
    How about some stickers?
  9. Prodigyplace
    11,755
    11,345
    Central Virginia
    All Primes, like all Gen 4 Prius, have the radar cruise control. The radar sensor is located behind the front emblem. I would be very cautious about modifying anything on the front emblem.
    It is expensive too! :eek:
    from 2017 Toyota Prius Prime Parts - metrotoyotapartsnow.com
    MagnusAG99 and padroo like this.
  10. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    Those are nice! I saw some similar on eBay! I’m getting those as we speak.
  11. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
  12. Prodigyplace
    11,755
    11,345
    Central Virginia
    Make sure whatever you do is reversible. If you get radar sense errors you may need to remove your customization.
  13. citiprius
    241
    238
    51
    2018 Prius Prime
    PHV PLS: May be some chrome around it?
    Tideland Prius likes this.
  14. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    Hmm... maybe I’ll plastic dip that chrome piece is looks cool! Like a black accent
  15. SaraBBrown94
    SaraBBrown94 Active Member
    234
    262
    Pittsburgh PA
    Edit: nevermind. I found it and it's like $90 bucks.
    Where did you get that? what is that chrome piece called? I'm super interested :D
    #15 SaraBBrown94, Mar 22, 2018
    PHV PLS likes this.
  16. Prodigyplace
    11,755
    11,345
    Central Virginia
    Perhaps a garnish.
  17. SaraBBrown94
    234
    262
    Pittsburgh PA
    The radar will let you know immediately when you turn the car on if the Plasti Dip is too thick. I redid my front the first time I plasti dipped it because it was throwing 'clean me' errors. The second time I went in with the black then used a special paint over top of it to do a design then a gloss Plasti Dip over top and the radar works fine. The distance it senses things is the same too. I checked. 1521766584162.jpg
    MagnusAG99 and Travis64 like this.
  18. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    That came out nice! that for the info
  19. citiprius
    241
    238
    51
    2018 Prius Prime
    Do you need to remove the emblem for plastic dip? How did you do that?
  20. SaraBBrown94
    234
    262
    Pittsburgh PA
    No. Just throw some painters tape and newspaper around the emblem so over spray doesn't get on the front of the car or the plastic grill. That way cleanup will be easier. If you don't tape it off, you can peel the majority of the overspray then use WD-40 and a soft rag to wipe the rest of the overspray off.
