spark plug replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TucsonPrius, Jun 17, 2006.
  1. Mendel Leisk
    41,824
    I had a bike with spark plug wells that would collect a lot of crud. I took one of the plugs out, very carefully, then hacksawed just the threads of the plug off, glued that to a long/slim wooden dowel, reached it in carefully, screwed it back in. Then I was able to blast away with compressed air, clear the crud out, without spilling it into the cylinder.
    You could do this with the just the plug in place, actually not a bad idea, but the broader shoulders of the full spark plug impedes the compressed air blast. This is worth doing if you've got a real mess.
    jerrymildred likes this.
  2. Michael Warren
    Michael Warren Junior Member
    22
    Hickory NC
    I fixed it.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Great! So what did it turn out to be? We're a nosy bunch. :LOL:
  4. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    What Jerry said, what did it end up being?
    TomK
    dolj likes this.
