Replaced front wheel bearing - new noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by miked722, Mar 24, 2018.
  1. miked722
    miked722 Junior Member
    Michigan
    I just replaced both front wheel bearings in my 2007 with 126k miles. The symptom before was a loud humming that was worst at 32 and 64 mph. I would guess the frequency was about the wheel rotation speed.
    The left bearing was definitely bad, as you spun in by hand you could feel a bit of grinding and hear some noise. I replaced both sides with Timken brand bearings.
    Now, at all speeds, there is a low frequency noise that is loudest at highway speed where it is about 1/second in frequency. At lower speeds (30-40) you can barely hear it, but you can feel the vibration at a slower frequency. Acceleration/braking/coasting is all the same. Left/right turning is similar in sound.
    Any ideas? I put on my summer fronts (took off winter fronts) and the noise is similar.
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Brake disc to hub fitment? Did you clean the rust and junk from inside the brake disks? Just a peace of sandpaper works well for this.
  3. miked722
    Michigan
    I used a wire brush. I'm thinking now that my test drives never included braking hard enough to activate the disc brakes. I just got finished taking it all back apart with no obvious issues. I'll clean the rotors again, re-assemble, and hit the brakes harder this time around...
    Raytheeagle likes this.
  4. miked722
    Michigan
    Re-assembled after using wire brush and sand paper on inside of brake discs. Braked hard a few times (and got out and could smell a bit of brake pad). Noise still persisted at all speeds, still worse at higher speeds.
  5. miked722
    Michigan
    So I think I've figured it out. I replaced one of the new bearings with the better of the old bearing and the noise is gone. I must have received a bum new bearing. Now to call parksgeek and remedy the situation.
    bisco and Raytheeagle like this.
