2005 Gen 2 - replace blown JBL front speaker?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Metrolens, Apr 2, 2018.
  1. Metrolens
    Metrolens Member
    215
    My 2005 Gen 2 has a blown front driver's side JBL speaker. Can anyone advise best options?
    1. Would an Infinity primus pr6500cs be a good replacement? Would I need to replace both front speakers for this to sound right, or could I leave the working JBL in the passenger side door?
    2. I'm in LA - how much should the labor cost if a garage does the install?
    kenoarto likes this.
  2. Metrolens
    Metrolens Member
    215
    Answered my own question - I ordered a pair of JBL GT7-6, am going to install myself.
  3. UberXking
    UberXking Junior Member
    San Francisco, CA
    Try disconnecting both front door speakers. Then adjust the fader. Try it you’ll like it.
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    They look like 4ohm speakers, are the OEMs the same?
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    for some idiot reason the oem speakers are 3 ohms. sometimes engineers have the common sense of a gnat. however, the jbl speaker surround is replaceable. that's usually what fails.
  6. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    I had two blown JBL speakers in my 2005. it took only a couple of minutes to repair the cones with a speaker epoxy i picked up off EBay for $5
  7. Metrolens
    Metrolens Member
    215
    I successfully replaced the blown OEM JBL with the new GT7-6. I actually just left the other good OEM JBL installed in the passenger door, because it still works fine. I realize this mixes speaker impedances (4 ohm for the GT7-6, vs. 3 ohm for the OEM JBL), but it still sounds great, with half the work, and I'm not blasting the volume under any circumstances. It's not an audiophile setup for sure... but road noise kind of limits the upside there anyway.
    SFO likes this.
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Will put this here for reference: Prius JBL Audio system response, specs, and photos
    Found some foam rebuild kits online :
    jbl speaker repair kit | eBay (dual speaker kit)
    JBL Speaker Repair Kits: How To Repair Foam Surrounds on JBL Woofers (single speaker kit)
    Speaker Surround Refoam Kits in the Speaker Components Department at Parts Express | 328
    Refoam Kits 6" - 8" Archives - Speaker Exchange
    Any have a clue which kit(s) would work/fit, or the speaker model # for the JBL 6.5 (16cm / 6.3 in ??) in the Gen 2?
  9. natasha lee
    natasha lee New Member
    india
    2016 Prius c
    Hi all! My 2005 Prius has a blown JBL front speaker. I’m thinking of replacing it with JBL GT7‑6 or trying a refoam. Has anyone here had success refoaming? Curious which option sounds better long-term. Any tips or recommendations would be greatly appreciated. Thanks in advance.
