  1. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    I need some urethane side skirts for prices like this! Anyone know of some decent urethane side skirts that are not terribly expensive? Years ago apparently the 1st owners jacked the car up on both sides in the wrong spot and actually on the side skirts and mine have a spot on both sides that's not too bad, but I notice it for sure and it drives me crazy. Reason why I never installed my CF pieces to my side skirts.
    Johnsk93 likes this.
  2. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    Couple items came in.
    Spc front camber bolts adjustable up to -1.75 degrees or so and real camber -3 camber shims
  3. Knaplullig
    Knaplullig Junior Member
    28
    99
    Gouda
    2013 Prius+ MPV
    Opted for the relay option. Figured I could always add the switch later if I ever want to.
    It's setup in the way that's its on with ACC, on with parking light and off with low beams.
  4. potatoesLOL
    potatoesLOL Active Member
    145
    413
    Downtown Los Angeles
    - Installed Cross-Drilled/Slotted Rotors & Ceramic Brakes.
    R1 Concepts
    Love the look, definitely lost some MPG’s though :ROFLMAO:. Slight improvement in braking
    - Alignment. Comped with brake install
    - Detailed vehicle. Prepping for scratch removal, paint and wet-sanding
  5. Daigi_
    Daigi_ Active Member
    198
    427
    Hacienda Heights
    Took a break from the wing... To start on a front lip. IMG_20180428_173820.jpg
    Pixel 2 XL ?
  6. Grit
    Grit Senior Member
    6,519
    4,214
    Wilkes Land
    68 mpg on 380mi 7 hr drive. HUD on max brightness w/AC lowest speed ECO mode. Additional 40lbs on glass as roof.
  7. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    Did you really lose MPG? I've got the same rotors on my Prius and didn't. Notice any reduction in MPG, just a nice bump in stopping power.
    James Powers likes this.
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    U might want to double ur rotors. I believe they are put on the wrong side. The slots should face forward, not backwards.
    iPhone ?
  9. BlkGenIII
    BlkGenIII Active Member
    86
    258
    SoCal
    Routine maintenance from the bros at Hybrid Pit... they went above and beyond to correct some over torquing from a previous dealer tech. Thanks guys :)
  10. Grit
    Grit Senior Member
    6,519
    4,214
    Wilkes Land
  11. potatoesLOL
    145
    413
    Stopped by HybridPit on my way back from Irvine today :cool:
    // Installed //
    - Cusco Front STB
    - Toyota Premium Horn 400/500
    I’m honking at everything right now hahah. Pretty sure the novelty will not fade. The stock horns don’t even come close to the premium. The Cusco STB is awesome too and definitely recommended. The improvement in handling is worth the upgrade.
    Happy with both :D
    - Lee
    m3pare, RightOnTime, sfv41901 and 8 others like this.
  12. Daigi_
    198
    427
    Hacienda Heights
    Early stages. About 5 hours in. Ran out of fiberglass and used carbon fiber instead. Nowhere near being done, but you can see the overall shape. The end product won't likely be carbon fiber. IMG_20180429_165619.jpeg IMG_20180429_165628.jpeg
    Pixel 2 XL ?
  13. Nopho4u
    1,007
    2,061
    Socal son
    Project kics leggdura 2pcs shell type lug nuts for my new wheels when they come in
  14. Accordlayingkit
    1,616
    1,747
    377
    Liked twice! But took my like away so had to like again... 3 likes!! Lol (y)
    Nopho4u likes this.
  15. Nopho4u
    1,007
    2,061
    Socal son
    Your gonna break ur like button in about a month or sofor the wheels:ROFLMAO:
  16. farmecologist
    farmecologist Senior Member
    1,957
    1,799
    Southern MN
    Interesting..I just installed these too! I won't post pics here...as the install was on our Prius v (wagon) but they exist here :
    Hi all, new Prius v owner | Page 3 | PriusChat
    Geez I'm jealous of how nice your suspension components look. Ours are rusty as heck ( midwest winters take their toll I guess ). Anyway, sorry to dirty up this thread with my 'Prius v' related crap. :whistle:
    potatoesLOL and RightOnTime like this.
  17. Accordlayingkit
    1,616
    1,747
    377
    Haha I'm already breaking the bank son!!! :whistle:
    potatoesLOL and Johnsk93 like this.
  18. Nopho4u
    1,007
    2,061
    Socal son
    Damn son why are you replacing those
  19. Accordlayingkit
    1,616
    1,747
    377
    Ummmmm rear washer removal :whistle:
    Daigi_ likes this.
  20. potatoesLOL
    145
    413
    Damn those are sexy- looking forward to the wheels!!
