Service Menu Prius 2016
Discussion in 'Gen 4 Prius Technical Discussion' started by Rodrigo Frade, Apr 22, 2017.
  1. Mendel Leisk
    41,645
    Which battery? If the 12 volt, I think you'd be better off with a digital multimeter, and a digital load tester, for more in-depth. The car's menu will just dutifully report the "on" voltage, which doesn't means nothing.
  2. Prodigyplace
    12,593
    11,791
    Central Virginia
    See Post 20. The last screenshot shows the 12 volt battery in READY mode as being 14.0 V.
    I imagine it would be lower in ACC mode. If so,it could be useful in detecting a bad 12 volt battery,
    RCO likes this.
  3. Mendel Leisk
    41,645
    That's what I mean, even a near-dead battery will read 14.0 volts under those conditions. As my father-in-law was want to say: you've gotta have the right tools.
    RCO likes this.
  4. Prodigyplace
    12,593
    11,791
    Central Virginia
    That may be why @kithmo originally used ACC mode. I was too lazy when I got to work & curious if the dance worked in READY mode.
    RCO likes this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Mine showed 11.4V (ACC mode)
    RCO likes this.
  6. Prodigyplace
    12,593
    11,791
    Central Virginia
    Do your menus look like mine?
  7. Prodigyplace
    12,593
    11,791
    Central Virginia
    The menu gives you real-time voltage readings from inside the car. I verified that the voltage was much closer to 12 volts in ACC mode.
    Now the question is, what is the OP going to do with this secret treasure trove of information? Inquiring minds want to know...
    kithmo and Mendel Leisk like this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Yes.
    Prodigyplace likes this.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    If he shows you his, are you gonna show him yours? :whistle:
    kithmo likes this.
  10. Prodigyplace
    12,593
    11,791
    Central Virginia
    Been there, done that.:D
    Hint: Post 20 & bonus points for Post 19 :LOL:
    kithmo and RCO like this.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    RCO likes this.
  12. K_W
    K_W New Member
    Hong Kong
    Hello,
    I also would like to know how to get into the services menu in my prius gen 4 (HK)
    My prius doesn't "CAR" Button & "SETUP" Button.
    Please assist to teach me how can I to do.
    Thank You
  13. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The button is on the RH of the steering wheel. The Manual will show you -
    #33 alanclarkeau, May 3, 2018
    RCO likes this.
  14. K_W
    K_W New Member
    Hong Kong
    Thank you.
    Let me try first
    Besides, which parts of the services menu for driver should be pay more attention / aware on it?
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I would try holding the "MENU" button and turn the lights on and off 3 times.
    The "SETUP" button on ours opens a menu so your menu button may logically be the same.
    RCO likes this.
