Single "Click" Sound When Accelerating Off Line and Every Time Brakes are Pressed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ZBrink, Mar 7, 2016.
  1. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    My 2010 with 110k is now making a single yet audible "click" sound when I accelerate off of the line. It makes the same exact sound each time I press the brake pedal at speed. Just one click, not a continuous clicking. What's wrong??
  2. Former Member 68813
    3,524
    983
    US
  3. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    Well considering it never did this before yet as of a week ago it does it consistently, I would say something is not normal here.
  4. bisco
    52,000
    maybe time to thoroughly inspect and service the brakes. Can you record and post?
  5. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    Rotors and pads were replaced on all four corners in 04/2015.
    It sounds as though something is engaging/disengaging but I have no idea what it could be.
  6. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    Problem figured out. It is the spring action on the left front brake pad. The pad is sliding ever so slightly and causing the clicking sound. No harm, no foul.
  7. doctor-jabs
    doctor-jabs New Member
    Atlanta, GA
    thanks for your post. i am having the exact same thing, so i hope this is all it is. firestone suggested it was an issue with the brake power brake booster and that i would have to take to the dealer.
