Removing the plastic engine cover
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by UltraJetRefill, May 29, 2018.
  1. UltraJetRefill
    156
    93
    Tucson, AZ
    I found this thread for a Gen 3. Quick question, is it the same for Gen 4, just pull up? No fasteners?
    Removal of engine cover | PriusChat
  2. krmcg
    2,592
    2,392
    Whittier, CA
    Yes. Pull straight up.
    UltraJetRefill likes this.
  3. UltraJetRefill
    156
    93
    Tucson, AZ
  4. David E. Edwards
    David E. Edwards Junior Member
    25
    Sugar Land, TX
    Be careful as I cracked mind on a cold Texas morning. Now I will use two fingers, one on each side of
    the fasteners, and pull straight up.
    RCO likes this.
  5. Mendel Leisk
    41,865
    Not sure how/if it'd work on 4th gen, but with our 3rd I put my thumbs on the edge of the bottom-of-windshield edge, grip under the ends of the cover at both ends with my fingers, then just moderately pull up. It slowly, slowly loosens, then pops off against that windshield edge.
  6. Tande
    Tande Active Member
    550
    337
    Mich.
    FWIW.....& then lubricate the rubber/grommets with silicone spray......(y)
