High temperature warning light
Discussion in 'Gen 3 Prius Main Forum' started by Victor B, Sep 8, 2017.
  1. Victor B
    Victor B New Member
    Portland OR
    I
    high temperature warning light goes on more and more often when Im going up on hill.. the light its not flashing its just staying on until I slow down. I know when its flashing then its related to water pump but in this case its staying on and after that when I open the antifreeze reservoir its not a lot of pressure there. But while I'm driving I can hear how the antifreeze its pouring or traveling through in front of me under dashboard and usually the high temp warning light comes on after a specific sound of pouring antifreeze..and this can mean a few things; thermostat? I don't think so. I did try to get the air out from cooling system if there was any but I think there is another problem and like I said only the high temp warning light goes on and nothing else,
    The engine was replaced and has around 33000 miles
    Anyone has any ideas why ?
    Thank you
  2. JC91006
    JC91006 Senior Member
    16,802
    8,591
    Maybe it's telling you the car is overheating?
    Did you check the coolant level? Check for codes to point you to the direction of the problem?
    NutzAboutBolts and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    How many miles since the replacement engine was put in? How many miles on the car? What caused the engine replacement? Was a new water pump installed with the replacement engine?
    Keep us posted (y).
  4. Victor B
    Victor B New Member
    Portland OR
    I
    The car itself has close to 400.000
    The engine was replaced because of head-gasket but before replacement I tried to put 'BLUE DEVIL' .. on the cooling system in the hope that will fix the head gasket problem.. and worked for only 1 day after that I changed the water pump because got stuck inside (it looked like swollen inside) and we think that blue devil sh...t did this. After that I replaced the engine (a good one) and drove it for about 23000 miles until now ,
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,717
    1,757
    Bay Area
    There should be a check engine light, get the code and read what it says.
  6. Marin Catalin
    Marin Catalin New Member
    Romania
    Hi. I have a 2011 prius. I have a problem with my car since yersterday. At high speed, 130km/h or more, when i floor it, coolant temperature light appear. why ? the thermostat seems to work well, AC works fine, water pump is working ( not sure how good or bad ). check for any error codes, but nothing. any ideeas ? thanx.
  7. Marin Catalin
    Romania
    Same problem as yours. The engine has 400.000km an its working very well. Any ideea, Victor ? What did you do ? What s wrong with your car ?
  8. Adil Nawaz Khan
    Adil Nawaz Khan New Member
    Pakistan
    Hey friends did you find any solution to this problem? I was suggested to change DC to AC inverter which lies in front. Please let me when you know about solution to this.
  9. Adil Nawaz Khan
    Pakistan
    Brother i face exact same problem they told me it is hybrid inverter overheating problem change this. Now i don't know either i change it or to wait if any one have find other soloution like flushing hybrid coolent etc
    #9 Adil Nawaz Khan, Dec 23, 2020
  10. Silver_Bullet_2012
    Silver_Bullet_2012 New Member
    Santa Barbara
    bump
    as I am having the same issue. Warning light only comes on when I am flooring it up a steep hill, then immediately goes off when i let off.
  11. JC91006
    16,802
    8,591
    have you checked your oil level?
