Thinking about swapping to 0W-30 synthetic oil
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Pdog808, Jun 20, 2018.
  1. Pdog808
    Pdog808 Active Member
    431
    287
    Los Angeles
    2018 Prius Prime
    OK, I do know that this particular topic can start a "hoily" war but I'm just too damn curious about the subject :)
    Anyway - I was considering swapping to a 0W-30 synthetic (probably Mobil 1 when they have their rebates available - $13 for a 5 quart bottle just can't be beat!). Of course, this swap would only happen AFTER I finish my two free Toyota oil changes.
    I live in Southern Cal, so we don't have crazy temperature variations like those folks who live in Vegas or Minnesota. For us "crazy cold" is 40 degrees and hot is about 90. Yeah we're spoiled...
    The reasoning behind swapping to a higher weight synthetic is that I was hoping to reduce engine wear when the vehicle is fully warmed up and running at freeway speeds. I figure that using a 30W vs. 20W "could" contribute to that. I would expect a very small mileage hit, of course.
    On the other end of the spectrum, I definitely want to use zero (0W) weight synthetics to increase oil flow at cold starts as my driving habits usually involve only turning on the ICE when I am at highway speeds. I want to make sure that the engine has oil fully distributed from those cold starts and the very thin 0W viscosity will assist in that. That's why I would not consider a 5W-30 oil, by the way.
    My understanding is that Toyota recommended the 0W-20 oil to help make their CAFE averages although I would think going to 0W-30 would only involve a very small hit to their average. Also, I hear that the European standards call for 0W-30 anyway? Not sure about this one - maybe someone in Europe may chime in.
    Thoughts? Ridicule? Let me know - thanks!
    j12piprius likes this.
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    If you feel you know more than Toyota's engineers, go for it. I'll pass.
    E-GINO likes this.
  3. Mendel Leisk
    41,053
    Maybe Toyota's engineers aren't the only ones making the decisions?
    FWIW, I've used nothing but Toyota 0W20, and have no oil consumption at 75K kms. But I'm changing my oil (and filter) every 6 months, alway been less than 8000 kms (5000 miles), and more typically now about 4~5000.
  4. Pdog808
    431
    287
    Los Angeles
    2018 Prius Prime
    I'll probably be running my mileage out to at least 8k miles before changing. Not sure if I could wait until 10k... still used to changing about every 5k with conventional oil.
    About 33% of my mileage is EV anyway so 8k is more like 5.3k miles anyway. As long as I can get Mobil 1 synthetic cheap, it won't hurt to experiment. YMMV (pun intended).
  5. orenji
    orenji Senior Member
    5,887
    3,488
    You don't say if you have a Gen 4 or Gen 3?!
    I have a Gen 3 and use 0W-40 with no difference in performance or Milage. If you have a Gen4 I would wait till you get about 60k miles before switching to a heavier weight oil.
  6. Pdog808
    431
    287
    Los Angeles
    2018 Prius Prime
    I have a 17 Prime so Gen 4 I assume (it's in my profile btw). I have about 1.5 years to think about it as I just had my 1st free oil change at 10.3k miles in March. I also did my own oil change at 3k miles and for that one I used Mobil 1 Adv. Performance 0W-20.
  7. orenji
    5,887
    3,488
    Mobil 1 runs on the thin side. So it has been said that 30 weight is more like a 20 weight. So if you really want the added protection go with 40 weight. It will be interesting to see if the GEN 4 start to burn oil as they get older. BTW I don't see it in your profile.
    Starship16 likes this.
  8. Pdog808
    431
    287
    Los Angeles
    2018 Prius Prime
    Hm.. it says 2017 Prius Prime under my name in the forum. We may be thinking of different things for my profile.
    In either case, I think 0W-30 would be the highest I would go.
  9. Mark57
    2,945
    2,740
    OK
    I'd invite you to do some reading on "Bob is the Oil Guy" site and others. You might fine some actual researched answers to your curiosity. He's been around for a long time.
    This is a very "emotional" subject just like the octane subject. Lots of FUD and lots of "my daddy did it this way" opinions. Do some reading. You might be surprised.
    E-GINO and Pdog808 like this.
  10. Mendel Leisk
    41,053
    Maybe @orenji 's viewing on a phone?
    Pdog808 and orenji like this.
  11. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    If it will somehow make you feel better, then DO it.
    Not only will the fuel mileage change be so small as to be undetectable, any other changes will be equally as small.
  12. Pdog808
    431
    287
    Los Angeles
    2018 Prius Prime
    Yup, I have read through dozens of posts from that site. One thing you can be sure of - those guys are SERIOUS about oil. Some of them are a bit ... obsessive... but hey maybe that's just me :rolleyes:
    Mark57 likes this.
  13. Mark57
    2,945
    2,740
    OK
    They're the "PriusChat" of the motor oil world.;)
    Pdog808 and jerrymildred like this.
  14. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    Does your Prime use the cartridge or canister? If cartridge, what part number or url link do you have?
    Thanks
  15. Pdog808
    431
    287
    Los Angeles
    2018 Prius Prime
    Cartridge, part number 04152-YZZA6 or 15613-YZZA6 (which seems to be the TRD equivalent according to comments on the Amazon link below).
    or at your local dealer if there's any question about part numbers.
    My local dealer wanted about $7.50 per filter btw.
  16. Mendel Leisk
    41,053
    Thanks. That's also the third gen oil filter "element".
    Pdog808 likes this.
  17. triggerhappy007
    498
    334
    Thanks. Oops I meant to ask for the part number of the removal tool for the cartridge. What's that one and is it easy to remove? I've never done a cartridge before. Thanks
  18. Mendel Leisk
    41,053
    The permanent plastic housing style is 14 flutes and 64 mm face-to-face of flutes. The spin-on, disposable metal cartridge I'd suspect is the same size. This is also Honda's standard size, btw.
    There's a plethora of oil filter sockets available. I'm using the (heavy-gauge stamped steel) Honda socket. The number on mine is obsolete; I believe the current number is:
    07AAA-PLCA100
    A couple of links:
    (Above is an Amazon link, might not display if you're using an ad blocker.)
    Genuine Honda Oil Filter Wrench (65mm) - 07AAA-PLCA100
  19. Pdog808
    431
    287
    Los Angeles
    2018 Prius Prime
    Edit: Sorry noticed Mendel's reply just now...
    Edit 2: One other item - go and get a 27mm socket - you HAVE to use the socket to loosen the cartridge otherwise you will probably strip out the 3/8" hole in the cap. You only use the 3/8" socket in the cap for TIGHTENING.
    #19 Pdog808, Jun 22, 2018
    triggerhappy007 and Mendel Leisk like this.
  20. Mendel Leisk
    41,053
    The more the merrier.
    Pdog808 likes this.
