Please Help Prius 2004 MFD Very Slow
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusProudOwner, Jun 14, 2018.
  1. PriusProudOwner
    PriusProudOwner Junior Member
    71
    so i can take a mfd from a newver prius and just changed it ? if ever i wanted to also last question i just changed the oil and filter is there a reset on the mfd or something ?
  2. PriusProudOwner
    71
    and the maintnance required light never was on and the oil was due it vent 7000km without changing the oil
  3. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    @Mendel Leisk, so how does this work on Canadian Prii?
    #23 dolj, Jun 21, 2018
    ITBland likes this.
  4. PriusProudOwner
    71
    what on earth are you talking about pal ?
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    He’s trying to be helpful and tagging a member who is more familiar to get you an answer ;).
    ITBland, Mendel Leisk and dolj like this.
  6. Mendel Leisk
    38,718
    Canadian third gen Prius don't have a maintenance light, I'd suspect that holds true for second gen as well.
    Raytheeagle likes this.
  7. ITBland
    ITBland Active Member
    433
    272
    New Orleans, La area, US
    Pg. 122 of the US owner's manual:
    (j) Engine Oil Replacement Reminder Light (for vehicles sold in U.S.A.)
    This light reminds you when to replace the engine oil.
    This light will come on when the “IG−ON” mode is enabled, and will go off after about a few seconds.
    When you drive for about 7200 km (4500 miles) after engine oil replacement, this light illuminates for about 3 seconds and then flashes for about 12 seconds when the hybrid system is in the “IG−ON” mode. If you continue driving without engine oil replacement, and if the driving range exceeds 8000 km (5000 miles), the light will come on after the “IG−ON” mode is enabled. The light will remain on thereafter.
    If the light is flashing, we recommend that you replace the engine oil at an early opportunity depending on the driving and road conditions. If the light comes on, replace the oil as soon as possible.
    The system must be reset after the engine oil replacement. Reset the system by the following procedure:
    1. Press the “POWER” switch to the “OFF” mode with the odometer reading shown. (For details, see “Odometer and two trip meters” on page 115.)
    2. Press the “POWER” switch twice to select the “IG−ON” mode while holding down the trip meter reset button. Hold down the button for at least 5 seconds. The odometer indicates “000000” and the light goes off.
    If the system fails to reset, the light will remain flashing.
  8. PriusProudOwner
    71
    prius 2004 is 2cnd generation i think right ?
  9. PriusProudOwner
    71
    the problem came back a day after so what do you think i should do change the whole panel fuses ?
  10. PriusProudOwner
    71
    i figured that one out but you guys have priuses 2006 and up so please no need help from someone that does not have the same model if you know something about the prius 2004 than please help if not just keep on rolling and seeking for people who need help with models you guys are owning or familar to thank you i would like this page to stay on the same road prius 2004 base mfd problems ;)
  11. JC91006
    JC91006 Senior Member
    16,482
    8,399
    It sounds like you have a MFD that's not working properly, just replace with another unit
    Raytheeagle and ITBland like this.
  12. Ray Moore
    Ray Moore Active Member
    857
    52
    I had a 2004 Prius previously. They had just started using lead free solder. There is a 60 pin connector that is used with the MFD. There is an old thread here about this issue. Pin #60 had a crack in the solder joint on many of these units because they didn't have the new solder figured out perfectly. The connector is only about an inch wide so you need magnification to see the crack in the solder. The crack is in the socket mounted to the board. Mine started actin wonky at mile 116,000 and about 4.5 years old. It was 80,000 miles out of warranty but Toyota fixed in under extended warranty because I was able to show them the crack on my board with 28x magnification and compared that to the pictures I found on this board. The mfd is not difficult to remove and instructions are found on this board. This may be your issue.
    ITBland likes this.
  13. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Glad to see you have an open mind (n).
    Good luck (y).
    bisco and PriusProudOwner like this.
  14. PriusProudOwner
    71
    i would not come here if i would chose to buy a new mfd for 600$ for a prius 2004 buddy that is why i created the post to find out if thre is a possible way to refresh reset or fix this small issue i bought the prius for 3500 why buy a new mfd for 600 if it can be fixed by someone who knows how let just see if there is hope if not i will close the thread and go to a toyota dealership but before all that something must be there to fix this little issue because when i pull out the fuses and put em back in it was perfectly fine for 1 day
  15. PriusProudOwner
    71
    finally someone that can actualy help meeeeee can you please explain more about the issue and do you have a picture of this so i can show it to someone to solder it correctly please please i really need your help on this one PLEASE :(;):):confused::cool::p:D:eek:
  16. JC91006
    16,482
    8,399
    I'm sure his repair was to replace with new unit
    ITBland likes this.
  17. JC91006
    16,482
    8,399
    I sold a used MFD for$40
  18. TMR-JWAP
    TMR-JWAP Senior Member
    6,226
    5,910
    Columbia, SC
    This thread is awesome......
    Raytheeagle and bisco like this.
  19. Ray Moore
    857
    52
    That is correct. You will find not find someone able to resolder this connector. I don't have time to do the search for you but it shouldn't be too hard to find. Please try to be kind to those that are trying to help you. It will make others more willing to offer their time.
    ITBland likes this.
  20. Ray Moore
    857
    52
    ITBland likes this.
