Telematics device hurting mileage?
Discussion in 'Gen 4 Prius Fuel Economy' started by csk47, Jul 6, 2018.
  1. csk47
    csk47 Junior Member
    Port St. Lucie, FL
    My 2016 Prius Two had been consistently getting 52mpg since I bought it new two years ago. I switched insurance carriers to All State and agree to have a telematics device installed to measure my driving habits and thus qualify me for a rate reduction. From the time I inserted the device in the port under the steering wheel it seems my mileage has dropped 3-4 mpg. Nothing else has changed in my driving. I am tempted to remove it for several days to see if my mileage returns to what I consider normal. Has anyone else experienced a mileage drop after installing a similar sensor for an insurance company?
    Thank you..
    Casey
  2. Leadfoot J. McCoalroller
    8,148
    7,651
    Pennsylvania
    2018 Prius c
    I wouldn't expect the device to have any impact, but it's hard to rule it out too.
    Some people subtly change their driving patterns when they know the insurance company is watching- possibly enough to bump the MPG? Tough to say.
    Most insurance companies only need to pull a 30-day sample. I guess I would run out the clock and see if it gets better afterward.
    RCO likes this.
  3. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    There's no way the telematics device will affect your fuel economy, other than the almost immeasurably small reduction in economy due to the mass it adds to your car, and the additional tiny electrical power drain. They only read the very basic standard ODBII protocol data (e.g. speed). They can't make any adjustments.
    I would suggest it's things like the warmer weather increasing the load on your aircon.
  4. bisco
    52,393
    how do we know the device can't be used by unscrupulous people with black boxes that can intercept and reprogram prius ecu's?
  5. The Professor
    598
    809
    UK
    Excel
    It's theoretically possible to create an ODB dongle that can reprogram a specific make and model of vehicle, either by adjusting factory settings, or updating the firmware (which puts the car out of action for several minutes so would be kind of noticeable). Given the huge number of variants of protocols, ECUs, makes, models, etc of vehicles, it simple wouldn't be economically possible to do this (nobody will pay thousands per dongle, nor hundreds of thousands for development, to achieve this).
    But let's assume a Prius is targeted, and they have some way to adjust some setting that drops someone's MPG by an almost unnoticeable amount, that is so small it's insignificant compared to the the day's weather conditions or tiny variations in a person's driving style... Why? Why would anyone want to do this? What would it achieve? And how would it be worth the expense in research, development, and production, to create these devices to ship to insurance customers, and how would it justify the risk of (quite easily) getting caught?
    Pixel 2 ?
    RCO and krmcg like this.
  6. Leadfoot J. McCoalroller
    8,148
    7,651
    Pennsylvania
    2018 Prius c
    What about a data gathering dongle that polls too frequently and inadvertently creates a denial-of-service situation where the ECU can't maintain normal operations? That situation doesn't require any specific targeting or even bad intent.
    ...what about a perfectly ordinary dongle with a loose connection, flooding the channel with NACKs or the equivalent?
    I really, really don't think that's what's going on here, just swimming the seas of speculation...
    RCO and Mendel Leisk like this.
  7. The Professor
    598
    809
    UK
    Excel
    You can DOS OBD, sure, and it can have weird effects. In my previous vehicle, the steering warning light would come on, but nothing else happened.
    I can't say much more as my experience is limited in this area of pentesting.
    Pixel 2 ?
  8. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    You should be able to counteract the drop in mpg by installing the Fuel Shark! ;):confused::p:D:eek::rolleyes:
    krmcg likes this.
  9. The Professor
    598
    809
    UK
    Excel
    ...or one of those magnets that wrap around the fuel line! ;)
    RCO and alanclarkeau like this.
  10. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Odd - if anything, I'd have expected it to have improved with you aware that "big brother" is monitoring your driving.
    I GOOGLED "Telematics device hurting mileage" - and it came up with not just this thread, but some interesting complaints, though none about PRIUS - maybe worth reading.
  11. Leadfoot J. McCoalroller
    8,148
    7,651
    Pennsylvania
    2018 Prius c
    Piffle. I just hold the pump handle with my left hand so it doesn't count as fast.
    RCO likes this.
  12. padroo
    padroo Senior Member
    2,763
    2,252
    This has all the sounds of another (music) Conspiracy Theory.:D
    RCO likes this.
  13. kens97uber171
    kens97uber171 Active Member
    177
    133
    US
    Ive had the Bluetooth dongle connected to torque occasionally toss a check engine light when your watching active data.. in the screen.
    I think the excessive polling of the data can cause some issue. I'm driving a 2008 with 236,000 miles.
    SM-N950U using PriusChat mobile app
  14. GadgetVirtuoso
    Fort Worth, TX
    2018 Prius
    I have an Automatic Pro connected to my 2018 Prius Two and don't have any issues with mileage, in fact on my commute home today I was able to drive over 30 miles and obtain over 70mpg according to both the car and the device.
  15. RRxing
    2,554
    1,828
    NEPA
    And don't forget... TORNADO AIR!!!
    RCO and The Professor like this.
