Horn stopped working
Discussion in 'Gen 3 Prius Technical Discussion' started by yanivz, Feb 12, 2018.
Tags:
  1. yanivz
    yanivz Junior Member
    israel
    My 2011 prius horn stop working. Can someone please tell what's wrong and how it can be fixed?
  2. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    You have four likely causes:
    A bad horn can stop working
    A bad fuse/relay
    A short/open in the horn circuit
    Check all those
  3. analoggirl
    analoggirl Member
    131
    26
    Asheville, NC
    Yanivz,
    Did you find a solution? Dealership wants to charge me $800 for just the horn assembly to fix/replace it?!
  4. bisco
    52,386
    clock spring
    ITBland likes this.
  5. Sidewayzgt
    Sidewayzgt Junior Member
    Los Angeles
    I second the clock spring (spiral cable). My horn just stopped working again today.
