Which Spark Plugs?! Denso SC20HR11, SC16HR11, or IXEH20TT??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HaiImBrian, Jul 11, 2018.
  1. Denso SC20HR11 (Original in manual)
    40.6%
  2. Denso SC16HR11 (New hotter plugs that Toyota superseded original plugs)
    34.4%
  3. Denso IXEH20TT (Brand new tech offered by Denso)
    25.0%
  1. HaiImBrian
    HaiImBrian Junior Member
    45
    Los Angeles
    This seems like a simple question but it really is not. I've done some research and since the plugs in our Prius pretty much last forever, I wanna put the best and correct one in. Each of these has been recommended and I was wondering which one to get.
    Denso SC20HR11 - Original Plug that is stated in the owners manual
    Denso SC16HR11 - New plugs that were superseded by Toyota to replace SC20HR11??
    Read More: Gen 3 Prius Spark Plugs superceded with hotter plugs | PriusChat
    Denso IXEH20TT - Brand new plugs and seems like the best tech available. but... these have different gaps than original. Gap at 0.040 instead of 0.044
    SFO likes this.
  2. Luckykat32
    Luckykat32 Junior Member
    22
    So Cal
    I'm currently using the new 44's and they feel fine. I think it's because I have a bad egr, but my car just started throwing misfire codes....i know more by next week
  3. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    I'm interested in the recommendations from other users since it's been bothering me too
    Mi MIX 2S ?
    Fostel likes this.
  4. bisco
    52,805
    what are the oems?
  5. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    I replaced the plugs week before last, holding my Official User Manual open to the page listing the spark plug part number. If it worked to 135,000 miles without a problem with the SC20H11, why risk fate with a different part? Now, had it been a later model Prius that called for the hotter plugs, or if the SC20H11 was Manufacture Discontinued (which it wasn't at Advanced Auto), then I'd have a different answer.
    But I have a lot less angst about this kind of thing after replacing the plugs. The ones I took out were good looking (tan on the ceramic) and, while a bit worn, the gap was still pretty close. Compare this to my olde '71 VW Beetle which needed new plugs every 12,000 miles, not to mention distributor points and condensor, and everything had to be checked and re-gapped at 6,000 miles. And a new distributor every 50,000 miles or so because the distributor shaft would get wobbly on its bearings.. The Prius is a dream by comparison, despite having to take out the windshield wipers to do the work :).
    Robert Holt and Fostel like this.
  6. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Raytheeagle likes this.
  7. HaiImBrian
    45
    Los Angeles
    They are the SC20HR11, but if you dig around the fourms, it is saying that these plugs are being replaced with a hotter SC16HR11
    You're right about this. My stock plugs have been great(SC20HR11) and lasted me this long but as Prius owners, we want to maximize the efficiency of the car. If this is the new recommendation from toyota.... shouldn't we move towards it? Spark plugs make a huge impact on engine efficiency.
    Yea these are the new TT dual iridium tip ones that are on the poll as well. Denso IXEH20TT
    Has anyone else installed these?
  8. bisco
    52,805
    i wonder if and when toyota made the switch, and if any members have seen the new plugs in their cars?
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    No they don't. A spark is a spark. You have been brainwashed.
    Unless one kind of plug somehow somehow sends some of the voltage somewhere else besides into the spark, all of the claims about superiority are just marketing hype.
    And you need to understand what a "hotter plug" really is.
    That does NOT mean that the spark is hotter.
    It means that the design keeps the electrodes at a higher temperature; the spark is exactly the same.
    You only need a hotter plug if what you have now tends to foul with carbon.
    Having the electrodes run at a higher temperature might actually create a "hot spot" that contributes to compression pre-ignition and loss of power and potential engine damage.
    M43S7RO, CR94, Robert Holt and 3 others like this.
  10. milkman44
    591
    386
    Ky
    I thought these were the correct plugs so I ordered a set and installed at about 145,000 miles, just after 180,000 miles I started having intermittent misfires. I put the original plugs back in and no more misfires. The original plugs now have another 9,000 miles on them and still doing fine. The plugs that are listed as the right ones are iridium, but have a platinum ground electrode and didn't hold up.
    https://www.rockauto.com/en/moreinfo.php?pk=1293084&cc=1444360&jsn=369
  11. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Me thinks Toy is spec-ing the hotter plug in hopes they will burn coolant better:cool:...
    Based on how basically brand new my 2010's plugs looked at 120k miles, I'll stick with the 20's when it comes plug time for my 2014. The last thing these engines need (in my opinion) is a plug which may contribute to pre-igntion compounding the EGR issues. Sheesh...
  12. CR94
    CR94 Senior Member
    2,823
    1,238
    Northwestern S.C.
    Maybe you need the hotter plug to avoid plug fouling after the oil consumption reaches Toyota's "normal" rate of 1liter/1000km? Or earlier, if doing mostly short, low-speed trips? They must've found a problem with the 20s in some undisclosed circumstance.
    m.wynn likes this.
  13. Fostel
    Fostel Member
    99
    31
    Kent, England
    Excel
    Any updates on this?
    Did everyone switch to SC16?
    That's what Toyota dealership is offering me.
    Thanks.
  14. Mendel Leisk
    42,302
    I think I recall reading that the 20's were being phased out by Denso, replaced by the 16. Reading between the lines in the Denso literature, seemed that plug was almost exclusively for Prius?
    I'd go with the 16's.
    My Canadian schedule says for the spark plug replacement: replace at 120 mo / 160000 km, thereafter every 60 months / 80000 km. For me the 12 years will come first, will see how that goes.
    Steph1972 and Fostel like this.
  15. sbfoster777
    sbfoster777 Junior Member
    I actually get a little predetonation (knocking) in my 2011 Prius Two, ....lesser with Premium Top Tier gas, but still present. I wonder if it would help me to go to go one step colder than the 20's?
  16. Mendel Leisk
    42,302
    How many miles on it? By "premium" you mean higher octane selection?
    Toyota now recomends the Denso ...16, which is hotter. Pre-ignition, detonation, are caused by carbon build-up in the cylinder head, which, if I'm not mistaken, means you should be going to hotter plug.
    Grit likes this.
  17. Bbonez
    Bbonez Member
    40
    44
    I replaced the 20s with the 16th on the 12th of January and I have noticed any difference.
    another_tyson likes this.
  18. sam spade 2
    7,035
    2,804
    2017 Prius c
    NO.
    You need to find out what the cause is.....and not just throw guesses at it.
    The only way this will help is if the present plugs are caked with carbon, in which case you probably need HOTTER ones.
    SuperchargedMR2 and sbfoster777 like this.
  19. Mendel Leisk
    42,302
    In case it's not clear: a "hotter" plug will burn off carbon deposits better, and it's carbon build-up that causes pinging, little glowing carbon nodes igniting the charge early.
  20. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    There are posts here with people using non own plugs and experienced lower than their average MPGs. Once they put the old OEM plugs back in, mpgs went back to normal. It prompted them to buy oems, once the new oems were in, MPGs were same as the old oem plugs. So sparks were are different, so spark isn’t just a spark.
