brakes squeal
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Craig0812, Jan 7, 2005.
  1. Craig0812
    Craig0812 New Member
    36
    Houston TX
    Has anyone noticed that their brakes squeal when in reverse? I only notice it when I press on my brakes when backing up any time of the day. I never notice it when I'm stopping at a light or stop sign, etc.....
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    I notice it when I back out of the garage in the morning but not at other times.
  3. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Yep. Sounds like the brakes are many years old. Sort of kills the stealth mood.
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Some times the brakes sqeal just from surface rust, especially on the first use in the am. Especially after a really humid night, But if you getting it at all times it could be some dirt in the rear drums too.
  5. reesdude
    reesdude New Member
    67
    San Fernando Valley, CA
    yea my brakes kinda squeal, its only 1 day and 45 mi. old. It doesnt happen when i brake but when im slowly moving, and it not really loud, but quite.
  6. paprius4030
    2,077
    296
    York,Pa.
    Hye on a new car I've heard that the lingings have to seat with the rotors maybe you should try a few pretty hard apllications, don't lock them up but go fiarly fast and come to a quick stop. If you went a little easy on the brakes when they were new maybe you got a glaze on the lingings. No expert here for sure, but I've heard others more in the know LOL say this.
  7. Tideland Prius
    16,564
    Same. I noticed brake squeal when I'm in reverse with full lock. It seems to happen when it's wet outside e.g. rain or snow.
  8. MattD
    MattD Member
    109
    <div class='quotetop'>QUOTE(Craig0812 @ Jan 7 2005, 01:13 PM) [snapback]62260[/snapback]</div>
    I consistently have the exact same problem -- did it clear up for you?
  9. Tideland Prius
    16,564
    Note that in reverse, there is no regen so you're solely using the friction brakes.
  10. MattD
    MattD Member
    109
    <div class='quotetop'>QUOTE(Tideland Prius @ Aug 6 2006, 11:22 PM) [snapback]298917[/snapback]</div>
    Right...but allegedly my drums are "almost new" (and in reality, they are, at 5k, plus the dealer's visual inspection) -- so this seems odd?
