What every newb should know
Discussion in 'Newbie Forum' started by richard schumacher, Jun 8, 2008.
  1. Tamaruni
    Tamaruni New Member
    Oklahoma City, Ok
    I do not know, MagnetoBlue---I'm new--but, I have to tell you-- that is one bad-to-the-bone nomenclature (name) you have there! I think it's great!
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    The active Moderator could help you out oi you message @Tideland Prius ..
    .. or you could just start anew and forget the old name.
  3. AnnieMQ
    AnnieMQ New Member
    Fort Collins, CO
    2018 Prius
    Two Eco
    Thank you for these tips! I am definitely having a small learning curve on driving my new prius (2018 two eco) and these are helpful!
  4. SuperAndy
    SuperAndy New Member
    Ohio
    How do I create a post?
  5. Prodigyplace
    12,593
    11,791
    Central Virginia
    You just did.
    You mean a new thread?
    Are you using a web browser?
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,153
    Tampa, FL
    If you're using a browser and you want to start a new thread, you just go to the forum where you want that thread to appear and click the big blue button that says, "Post New Thread."
    If you're using a mobile app, I have no idea. It's way too cumbersome to try to engage with a forum on a mobile device.
    SuperAndy likes this.
  7. SuperAndy
    Ohio
    Thank you both! I figured it out.
    jerrymildred and Prodigyplace like this.
  8. LikeAPrius
    LikeAPrius Member
    100
    26
    2019 Prius
    Just read the OP and it seriously makes me to want to take my 2019 Prius back to the dealer, this is WAY more maintenance that I have ever seen on a car
  9. Prodigyplace
    12,593
    11,791
    Central Virginia
    You realize that post was written over to years ago for a car 2 generations older than yours?
    Much has changed & improved in that time.
    I did not think the 2019 Prius had shipped yet.
  10. LikeAPrius
    LikeAPrius Member
    100
    26
    2019 Prius
    Opps
    They have shipped, its a XLE FWD 5D HB
    #870 LikeAPrius, Feb 12, 2019
    Prodigyplace likes this.
  11. jerrymildred
    11,517
    14,153
    Tampa, FL
    I went back and looked at the OP. The only maintenance there was checking the oil. Of course you need to change it, too. But that's common to all cars except BEVs. As for scheduled maintenance, it's just fluid related. Oh, and you'll probably need new brake pads every 10-15 years.
    fuzzy1 likes this.
  12. parnami
    parnami Member
    227
    48
    .Lancaster, PA (Amish Country) :)
    I have never owned a car as reliable and low maintenance as my Prius! By far!
    WilDavis, fuzzy1 and jerrymildred like this.
  13. Christian Bjork
    Christian Bjork Junior Member
    Peru
    2019 Prius
    Two Eco
    Hi everyone! First post (and for the record, I haven't bought my Prius yet, but was asked to put what car I had when signing up to the forum) and curious if this (VERY helpful) post is updated for current models? I see it was originally created in 2009, if I'm not mistaken? Thank you all very much, and I look forward to reading up and catching up on the great amounts of information.
    Prodigyplace, jerrymildred and bisco like this.
  14. bisco
    52,093
    welcome!
    it isn't, but there's still a lot of good advice here. then look to the gen 4 forums for more specifics.
    all the best!(y)
    Christian Bjork likes this.
  15. jerrymildred
    11,517
    14,153
    Tampa, FL
    Welcome and congrats in advance! As @bisco said, there's a ton of good info in the Gen 4 forums. Have fun car shopping.
  16. Prodigyplace
    12,593
    11,791
    Central Virginia
    Welcome!
    Just to make things more confusing, Toyota changed the model names for 2019.
    For 2018 - 2018 there were One, Two, Two Eco, Three, Three Touring, Four, Four Touring.
    For 2019 there is L Eco, LE, , LE-AWD-e, XLE, XLE,-AWD-e and Limited.
    The 2 AWD-e models have 4 wheel drive.
    Christian Bjork and jerrymildred like this.
  17. jerrymildred
    11,517
    14,153
    Tampa, FL
    Yeah, the 1, 2, 3, 4 stuff was way too unconfusing. :(
    #877 jerrymildred, Mar 31, 2019
  18. Prodigyplace
    12,593
    11,791
    Central Virginia
    Like the change from roman numerals to arabic numbers that happened to have a liftback trim "V" that conflicted with the totally different Prius v wagon?
    jerrymildred likes this.
  19. Tideland Prius
    16,564
    I've updated the Model dropdown.
    Raytheeagle and Prodigyplace like this.
  20. SDK2005
    SDK2005 New Member
    Pittsburgh PA
    This is a very informative post and I thank you for it.
