Anyone replace an AC compressor themselves?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2ewes4me, Jun 18, 2018.
  1. 2ewes4me
    2ewes4me Junior Member
    33
    Has anyone here replaced an AC compressor by themselves?
    If so, would you share how difficult it was?
    Thanks
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    easy , disconnect battery ,just add the right oil and amount vacuum the air add the right freon and amounts .gauges and vacuum pump can be rented at oreillys
    Dxta likes this.
  3. Mendel Leisk
    38,733
    Using rented gauges could contaminate the system, it requires a special oil. There's a caution about this in Toyota literature.
    I can post some Repair Manual info in a bit.
    Myself, I'd just take it to dealership.
    Macs, ITBland and bisco like this.
  4. Mendel Leisk
    38,733
    Here's something:
    #4 Mendel Leisk, Jun 19, 2018
    Fostel, ITBland and Raytheeagle like this.
  5. 2ewes4me
    33
    Thanks for posting these pages, I'm sure they will be very helpful. AC still blowing cold following the last fill, so hope to not have to address this in the near future.
  6. ASRDogman
    ASRDogman Senior Member
    6,093
    3,273
    Is the compressor leaking? You said "AC still blowing cold following the last fill,". So how many times have you
    filled it, or had it filled? There is a leak somewhere.
  7. Seymour1
    Seymour1 Junior Member
    152
    17
    I read the shop manual instructions and am surprised that it did not require that the dryer and condenser also be replaced. A youtube stressed that they must all be replaced.
