Anyone replace an AC compressor themselves?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2ewes4me, Jun 18, 2018.
  1. 2ewes4me
    2ewes4me Junior Member
    33
    Has anyone here replaced an AC compressor by themselves?
    If so, would you share how difficult it was?
    Thanks
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    easy , disconnect battery ,just add the right oil and amount vacuum the air add the right freon and amounts .gauges and vacuum pump can be rented at oreillys
    Dxta likes this.
  3. Mendel Leisk
    42,343
    Using rented gauges could contaminate the system, it requires a special oil. There's a caution about this in Toyota literature.
    I can post some Repair Manual info in a bit.
    Myself, I'd just take it to dealership.
    Macs, ITBland and bisco like this.
  4. Mendel Leisk
    42,343
    Here's something:
    #4 Mendel Leisk, Jun 19, 2018
    Fostel, ITBland and Raytheeagle like this.
  5. 2ewes4me
    33
    Thanks for posting these pages, I'm sure they will be very helpful. AC still blowing cold following the last fill, so hope to not have to address this in the near future.
  6. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    Is the compressor leaking? You said "AC still blowing cold following the last fill,". So how many times have you
    filled it, or had it filled? There is a leak somewhere.
  7. Seymour1
    Seymour1 Member
    272
    36
    I read the shop manual instructions and am surprised that it did not require that the dryer and condenser also be replaced. A youtube stressed that they must all be replaced.
  8. Seymour1
    Seymour1 Member
    272
    36
    I watched many youtube videos. The instructions vary all over the place. 4 Seasons video was very technical. It is troubling that R-134a molecules wants to chemically attach to the POA oil. So, apparently, we must have enough oil in the system to assure that the compressor will always have some oil but not more than 4.9 OZs. It seems that the evaporator collects and keeps much of the oil.
    My compressor fails the megohmmeter test, so I should assume that the conductive oil is throughout the system. I think that I must flush the system to remove the dirty oil. The evaporator is the most difficult to flush because it is hard to get to the fitting where I will inject the flush liquid. I will need to buy a new expansion valve and modify it to flush my evaporator.
    In order to have the correct amount of oil in the system, I must have 4.4 oz to 4.9 oz of oil in the compressor. That assumes that the flush will remove 100% of the old oil. Has enyone done this? What do I need to watch out for? Will the flush remove 100% of the old oil? I plan to buy a gallon of flush fluid. Should I try to capture the old oil when flushing and measure the volume of it?
    Thank you for any advice.
  9. ChapmanF
    19,016
    It sounds like you're sure some conductive oil got in there, and is the reason for the compressor failing the megohmmeter test.
    If the dealer has a HECAT H-1000 flush device, or some other A/C specialist in the area has one, there may be a chance here. You can review this thread for an experiment conducted by the Automotive Career Development Center, where they successfully recovered from a wrong-oil situation by replacing only the compressor (ASAP), and just HECAT-flushing everything else, then doing a full recharge with the correct oil and refrigerant.
    It will be more than a few hundred dollars, but less than the cost of replacing all the components and lines, which was the earlier way of solving this problem.
