Servicing a 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jafca09, Aug 8, 2018.
  1. jafca09
    jafca09 Junior Member
    34
    Bay Area, California
    I have a 2010 Prius (purchased in 2009 new, just shy of 9 years old). It has about 65,000 miles on it.
    According to my local Bay Area dealership, I'm due for 60,000 mile major servicing — but also suggested I get the 90,000 mile major servicing given the age of the car.
    A few questions:
    1. Does the ~$750 cost for the 60k servicing and ~$1100 cost for the 90k servicing sound right? It struck me as quite expensive.
    2. Any advice on which option to pursue? To date, I haven't had any major issues with the car, I've kept up with regular servicing, and it hasn't been in any accidents.
  2. schja01
    schja01 Senior Member
    1,827
    1,217
    Chicagoland
    2024 Prius
    Limited AWD-e
    I think I would go by what Toyota recommends at 60k not the dealership.
    J
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,516
    2019 Prius Prime
    It sounds high to me;).
    What dealer are you using in the Bay Area? Do you perform any (or would you if you had the opportunity) of the maintenance yourself?
    If you have any incling to diy, we are coordinating a local meetup for the 25th in Lafayette:
    Possible Monthly install meets. Bay Area-Fremont
    If you want to come out, drop a line in that thread:).
    RMB and m.wynn like this.
  4. bisco
    51,521
    i would ask luscious garage what they recommend. in your case, it is more time than miles.
    btw, there are no major services at 60 or 90k. take a look in your maintenance manual. 120k is the major.
  5. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    HPrimeAdvanced likes this.
  6. bisco
    51,521
    hmm, luscious garage, why didn't i think of that?(n)
  7. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    Sounds high to me. (my last car was a 2010 Prius) I don't remember anything special at 60 or 90K, and definitely nothing that cost that much until well over 100K
    HPrimeAdvanced, FuelMiser and m.wynn like this.
  8. padroo
    padroo Senior Member
    2,763
    2,252
    Maybe a transmission fluid change, I don't think that is in the book either.
  9. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    I agree with other posters, there are no "major" services at 60 or 90K. Simple oil and filter changes, plus engine air cleaner, cabin air filter is all you need worry about. If you are really concerned, have them check the brake pad thickness and rotor condition, brake fluid level/clarity, coolant level and clarity. If you log/register at MyToyota.com and enter your VIN number, you can view the Service and Maintenance schedule published at Toyota...
  10. frodoz737
    frodoz737 Top Wrench
    4,647
    2,487
    33
    Respects...but I think it's time for you to learn how to do these simple tasks on you own vehicles.
    HPrimeAdvanced and Grit like this.
  11. Bob Comer
    708
    460
    I couldn't disagree more. It's his choice whether he wants to or not. Some people can't do it, some don't want to bother, and some don't have the time.
    I think he did the smart thing by asking others about it...
    HPrimeAdvanced, scona and jafca09 like this.
  12. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    As someone who did his own maintenance when younger:
    The Prius is low to the ground.
    The under cover hides a lot.
    The engine bay is really crowded.
    When I was young, I had time and energy but lacked money.
    Then, I had money and energy but lacked time.
    Now, I have money and time but lack the energy.
    I have business cards that say "if it can be done indoors, sitting down, I volunteer."
    HPrimeAdvanced, RMB, padroo and 2 others like this.
  13. Mendel Leisk
    40,968
    Just do the maintenance according to Toyota:
    The "reality" of the above, all they really need/should do (with estimated cost):
    1. Change the oil and filter. ($50~60)
    2. Rotate the tires. ($20~30)
    3. Inspect the Cabin and Engine air filters. I appreciate it says "replace", but do yourself a favour, just look them over, assess whether or not they actually need replacement. And if you want to start DIY'ing, this is the place to start, very easy check.
    4. Full brake inspection. This is not the "visual" inspection with tire rotation, it's the more complete, in-depth inspection. ($200)
    Everything thing else, the myriad inspections, superfluous fluff, should be waived.
    Ok, now I know they're having you on. Here's the 90K service:
    Compare to the 60K service shown above: they are exactly the same. This dealership is cooking up their own, "special", "recommended" service schedule. Not uncommon.
    #13 Mendel Leisk, Aug 9, 2018
  14. jafca09
    34
    Thanks, all. This makes sense. I called back and they gave me a more reasonable $200 quote to do the more minor maintenance. They also suggested replacing the brake fluid; they said it can degrade over time (that it's less tied to mileage). They also said they can't verify that before replacing it. Is that the case? It would be about $100 to replace it.
  15. Bob Comer
    708
    460
    No real clue on that one, but I don't remember replacing it.
  16. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
  17. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    I’ll put in a vote for replacing the brake fluid. Brake fluid, as Jimbo points out, is hygroscopic. Not sure what/if there are special requirements on the Prius for a brake fluid flush, but, $100 seems reasonable to me.
  18. Mendel Leisk
    40,968
    Toyota Canada recommends tri-yearly or 48K kms, at least as of 2012 they start saying this. For any and all their vehicles.
    Honda's said tri-yearly, regardless of miles, for decades, as long as I can remember. $100 is reasonable. Maybe caution them to test drive it after, and check to make sure they didn't lose any of the bleed bolt caps (you can see them without raising the car).
    DIY is basically the cost of the fluid (2 pints of Toyota DOT3, was about $15~16). I did it, with my wife pushing the brake pedal, about a year back. @NutzAboutBolts has a video on it, in the 3rd gen maintenance forum, pinned at the top.
    But yeah, $100 is reasonable, and a lot less stress, lol.
    NutzAboutBolts likes this.
  19. frodoz737
    4,647
    2,487
    33
    That's nice you disagree with me...and you are right...he is smart asking others about it. I simple gave advise based on the fact that most Prius Owners buy one to save money. Whether you disagree or not with that advise brings nothing to the table though. You're just telling the audience you don't personally maintain your own vehicles...for what ever reason.
    ...and yes jafca09, have the brake flush/pin lube/inspection done, get the transmission fluid exchanged and have both coolants exchanged...if you are not going to do it yourself. ;)
    #19 frodoz737, Aug 10, 2018
    Grit likes this.
  20. Bob Comer
    708
    460
    So arrogant. You telling people they must maintain their own car doesn't bring anything to the table either.
    Anyway, If you wanted to save money, a Prius isn't the proper car. If you want to save gas and cut co2, than it's the right car.
