Possible Monthly install meets. Bay Area-Fremont
Discussion in 'Local Prius Club Main Forum' started by Priusmpg, Jul 1, 2014.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    August 25th looks like it works for me:).
    Glad you and Mrs Pedal Logic worked for this date ;).
    Hope it didn’t cost you too much (y).
    GTprii likes this.
  2. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Hi Ray, care to do a write up and post pictures on how to install front shocks/struts and rear sway bar that you had experience with?:rolleyes:
    BTW, I won’t be able to make the 25th meetup, hope you guys enjoy.(y)
    Raytheeagle likes this.
  3. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Sorry to hear you won’t be able to make it:(.
    There’s always next time though;).
    For the front shocks, it helps to have a spring compressor, and @The Critic had the goods:).
    We had both front assemblies done in under 2 hours, but that included time spent admiring his setup;).
    Windshield wiper cowling comes off and elevate the Prius holding a stand or support for the wheel bearing hub assembly that will be free moving once the strut tower is removed.
    Swap the insulators at the base of the spring and put some new boots on and reinstall :).
    Always good to have another set of hands and a fantastic work area to make the job easy(y).
    GTprii and RMB like this.
  4. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Interested in the meet-up if possible. I don't have anything in particular i'm looking to do, just want to chat about tips/tricks and future maintenance work. Where are you guys planning to meet? Any special we gotta do to join?
    Raytheeagle and GTprii like this.
  5. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    We always welcome those who want to chat;).
    No special handshake required, just treat @Pedal Logic ’s place with respect as it is a convenient midpoint in Lafayette :).
    We need to stay on Mrs. Pedal Logic’s good side;).
    Pencil you in for social aspects on the 25th then:whistle:?
    Hope to see you there(y).
    RMB likes this.
  6. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Yup! Please do. How do i get an address? At what time do you guys meet?
  7. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    We PM those that have confirmed attendance about a week prior ;).
    Usually start around 10, but since it’s summer, maybe 9 this go round:).
    I’m an early bird (y).
  8. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Great, so i'll await the PM and thank you again. Have a good day
  9. gifuboiler
    gifuboiler Junior Member
    SF Bay Area
    Mind if I join you guys on the 25th?
  10. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Nope;).
    Always good to have more people there:).
    How’s the key working out?
    Any work you want to do to your Prius?
    See you the 25th(y).
  11. gifuboiler
    SF Bay Area
    Key works wonderfully! Thanks again for helping with that!
    I'm about to hit 60k miles. I was thinking about an oil change for sure. Not sure if I should do a transmission fluid change or not. Is it too early to do an EGR cleaning/intake manifold/oil catch can?
    RMB and Raytheeagle like this.
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    The sooner the better now that your 60k on the ODO.
  13. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    We could sign you up for the oil catch can, oil changed and trans fluid drain and fill;).
    IMO it’s a bit early on the egr cooler swap, but we can pull the egr pipe and see what we are dealing with:).
    See you on the 25th(y).
    RMB likes this.
  14. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    I am at 61k miles now, couple months ago right before I hit the 60K mark I had done transmission fluid at the last meet up at Memorial Day weekend, with help from Ray and @grid , and installed oil catch can at another meet up last November.;)
    Ray, do you still have the image of 130k vs 60k ATF? Definitely get the ATF done while you are doing oil change.(y)
  15. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    RMB likes this.
  16. gifuboiler
    SF Bay Area
    Looks like I'll be doing the transmission fluid too. I'll get everything ordered. Anything special I should order for the oil catch can? Like clamps or hoses?
  17. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I’d buy some fuel hose at oreillys or the like.
    I mounted mine low so I only needed 2 feet, but if you side mount by the inverter, you’ll need more.
  18. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I can do Sunday the 19th.
  19. mrjeff
    mrjeff Junior Member
    26
    los ang
    Hey,
    I'm near 100K miles and I'm thinking of driving up as I'd rather spend the money and learn something rather than give it to the dealership. I'm thinking I'd like to clean the throttlebody, EGR, replace spark plugs, and clean intake manifold. Is that too much? With the EGR, I'm considering buying a new cooler and doing a swap, but I'm wondering if the valve and pipe are easier to clean on the spot or will I need to procure a donor for those as well? Also - same question with manifold. Just want to make sure I am prepared and have everything I need.
    Thanks
    #539 mrjeff, Aug 13, 2018
  20. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    That'll be one helluva drive. You'll want the engine to cool down first to do the above so set your alarm early.
    I'm about 50 miles away from 100K myself and have the same to do list as yours. Saving it for colder weather though, hope all goes well at the meet up. I won't make it to this one.
