Prius Engine Noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by luis valery, Aug 7, 2018.
  1. luis valery
    luis valery New Member
    Hello, I have a Prius 2010 with 150.000 mi. and sometimes when the battery is running at low level (2 bars) and I'm parked and start accelerating the car (some time makes a suddenly engine noise, that's noise disappear when I speed up the car. I recorded it... If anybody know about it... I appreciated your help.. Thanks...
    #1 luis valery, Aug 7, 2018
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    death rattle due to plugged up egr circuit
  3. bisco
    52,351
  4. Michael King
    Michael King Member
    72
    33
    Raynham, Massachusetts
    2018 Prius Prime
    Hey, Mind expanding on the "death" rattle? My 150k car just started making a similar noise.
  5. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    It means the EGR cooler needs to be cleaned. Lack of EGR flow thru the cooler allows the engine to spark knock. Once the EGR cooler is removed and cleaned, this noise should go away.
    Raytheeagle likes this.
  6. Michael King
    Michael King Member
    72
    33
    2018 Prius Prime
    Ok Thanks. I guess the term "Death Rattle" sent my mind spinning with thoughts that the motor was done for and I had a very expensive visit in the future. This shouldn't be more than the average $300-400 reaming when the dealer has to do something. (Still expensive, but somewhat expected on a 150K car)
  7. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    Thirteen 10mm bolts to remove the wiper cowl and motor. Three 14mm nuts to remove the wiper arms. Four 12mm nuts, one 12mm bolt, and three hose clamps to remove the EGR cooler. If you have an afternoon free and a decent set of hand tools, you can do this yourself.
    A decent size storage container, a few gallons of water, and a container of Oxyclean will clean out the cooler. Let it soak in the Oxyclean solution. Thirty minutes to a couple of hours, followed by a hot wash with Dawn dishwashing liquid and water. Then rinse and blow dry with air compressor, if available.
    RMB and Aaron Vitolins like this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    If you go to the dealer, expect more than $400;).
    They will not clean the cooler and are not usually amicable to the egr circuit cleanse:(.
    Might want to look for an independent in your area for this task;).
  9. Leadfoot J. McCoalroller
    8,134
    7,641
    Pennsylvania
    2018 Prius c
    Relax. Car forums allow owners to discover common features and flaws in their cars, and examples of these often earn nicknames, and are often tongue-in-cheek or hyperbolic in nature.
    It's like picking a band name. Deäth Rättle!
    ITBland likes this.
  10. Michael King
    Michael King Member
    72
    33
    2018 Prius Prime
    So what do they do? Replace it?
  11. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    I have a clean spare ready to go;).
    I do the work myself, but some mechanics will take on the task and clean the egr pipe and I take manifold, some will not:(.
    You’ll have to call around to see, but as you’ll find reading here, getting this done after clearing 100 k miles is a must;).
  12. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Actually my car have 150000k+ km and i cleaned the whole EGR pipe and coolant system and all intake manifold parts ..but issue still the same and same sound came when drive in huge traffic crisis..
    The battery gose down to 2 bars then the sound came..i think this issue related to dying battery..
  13. tankyuong
    1,555
    662
    Central MO
    worst case scenario is blown headgasket which happened to me
