Weights attached to frame??
Discussion in 'Gen 2 Prius Technical Discussion' started by Flyin2Low, Aug 15, 2018.
Thread Status:
Not open for further replies.
  1. Flyin2Low
    Flyin2Low New Member
    NC
    So, I was reading the Prius group on facebook when I came across a discussion about removing weight from the vehicle. One poster asserted that Toyota added weights to the frame and posted a picture as "proof". Thoughts on this? Poster: "The car is already on the brink of too light for safety. Toyota literally placed weights all over the to give it more weight....If you remove the front bumper there one on each side of the frame, I want to say they weight like 15lbs?...Take off your bumper and you can see them for yourself....See that little black thing on the frame? That’s a weight.....I put an air horn right there. I removed the weight to make it fit. There’s another on on the opposite side too. It literally bolts right on and weighs like 15/20 pounds, it’s literally a hunk of steel....What other purpose would a chunk of steel serve? There’s no wires connected to it, just 1 10mm bolt holding it on, and like I said earlier, there an identical on the other side. I didn’t look in the rear of the car but I’m assuming theres one in each corner."
  2. PriusCamper
    PriusCamper Senior Member
    12,795
    5,180
    Pacific Northwest, USA
    Hmm... Never heard of this?
  3. Flyin2Low
    NC
    The poster just advised me he has a base model 2007 prius.
  4. bisco
    52,001
    part of the crush zone?
  5. Leadfoot J. McCoalroller
    8,094
    7,577
    Pennsylvania
    2018 Prius c
    Maybe it adds enough mass to the crash beam to make the airbag sensors work right?
    All I got.
  6. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    Is there a part number on it? the name might give a clue as to the function.
  7. bisco
    52,001
    i can't see toyota adding weight for no reason. they don't put in sound dampening because of a few pounds of weight.
    is the prius really that light compared to other cars in its class? it has proven to be very safe in a crash and passes all the insurance testing.
    jerrymildred and Raytheeagle like this.
  8. ITBland
    433
    278
    Maybe it is an oscillation damper of some sort.
  9. PriusCamper
    12,795
    5,180
    Yea, I tend to agree... It makes sense that it's part of the collapse during a crash design to save your life, but would rather wait to hear what others know about it? Seems adding 60 pounds of weight doesn't make much sense for a car that's designed to be as light as possible to boost MPG?
  10. ChapmanF
    18,250
    Is that 135 ✕ 240 picture the biggest that was in the original post? Can't see jack....
    -Chap
  11. Flyin2Low
    NC
    Yes, sorry Chapman, that is the picture he posted in FB. I agree that Toyota probably wouldn't add weight unless necessary for something.
  12. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    If you look long enough, you can find "one poster" who asserts almost anything.
    Including that the earth is flat.
    Flyin2Low likes this.
  13. ASRDogman
    ASRDogman Senior Member
    7,607
    3,915
    WHAT??? The earth is flat??????????
    William Redoubt likes this.
  14. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    And it's turtles all the way down...
  15. ASRDogman
    7,607
    3,915
    It's amazing the things you can learn in Prius chat!
    Who believes the sun raises in the east?
  16. PriusCamper
    12,795
    5,180
    But the OP wasn't asserting, they were asking our opinion... There's a difference!
  17. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    A few things:
    1) There is no such thing as "too light for safety." The Mitsubishi Mirage weighs 1800 lbs and has a 4-star crash rating; the Honda Fit weighs 2600 lbs and has a 5-star rating; our Gen 3 Priuses weigh more than 3000 lbs.
    2) The picture the guy posted is a Gen 2.
    3) The picture below, of a 2012 with the front bumper cover removed, shows no such weights. Also, I've taken 170 lbs off my car in the last couple months and had the bumper cover off several times; I like to think I would have noticed something as easy to remove as extraneous weights.
    PriusCamper and bisco like this.
  18. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Conspiracy. The prius owner placed weights on it and pointed a camera to it then posted photos. I mean the Kardashians put weight on and they get attention, I don't see how the prius weight would fail for attention also.
    Flyin2Low, Tideland Prius and ITBland like this.
  19. PriusCamper
    12,795
    5,180
    Are we all being trolled by the OP who hasn't said a word since they posted? Sure seems like it...
  20. Tideland Prius
    16,559
    He replied twice.
Thread Status:
