Does anyone know the Prius prime spark plug type?
Discussion in 'Prime Main Forum (2017-2022)' started by Pdxprimeguy, Aug 16, 2018.
  1. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    I believe it is a Denso spark plug but I don’t have the number. Does anybody know what part number it is by chance?
    My Prius is showing some signs of hesitation or sluggishness. I have about 50,000 miles on my 2017 Prius prime.
  2. schja01
    schja01 Senior Member
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
  3. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    50,000 miles?!?!?
  4. krushmoto
    krushmoto Member
    65
    44
    US
    That's what I said!
    My wife's was purchased on 4/15/17 and just broke 6300. And that's only b/c I used it to commute to work a few times.
    Nexus 6P ?
  5. Salamander_King
    Salamander_King Senior Member
    11,023
    8,958
    New England
    Aren't they iridium plugs that supposed to last for 100k miles?
  6. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    I drive Alot. A whole lot. It’s been a good car. But with the weather hot and a/c on. For some odd reason the car has been a lot more sluggish when in sport mode if you will. And when at higher speeds. It just started a week or 2 ago.
    I give it premium most the time So i doubt if it’s the gas.
  7. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    How many engine miles...vs. electric miles?
    I'd think the sluggishness would be something else. Water in the gas? Very old gas or a bad tank full from a station with tankage problems? Try a good fuel system cleaner. Seafoam is one of many; follow the label instructions.
  8. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    I have used seafoam in other old cars and it does great stuff. I fill up with arco mostly. It is possibly bad gas. Will try a different brand. Tends to happen when it is hot 90f and up and I use a/c. And Also when I put it in power mode.
    I have a 240volt charger so I use at least 35+ miles electric daily. I average 40k miles a year.
  9. RRxing
    RRxing Senior Member
    2,553
    1,826
    NEPA
    From my owner's manual -
    DENSO FC16HR-C9
    I would imagine it's the same for the Prime - RTM...
    Pdxprimeguy likes this.
  10. cntkeepmedown
    cntkeepmedown New Member
    Vermont
  11. Mendel Leisk
    41,792
    Page 714 of the Owner's Manual:
    Hesitation might be bad gas, fuel filter. Maybe just run through most of the tank, fill up (at different station?) and see what that does. If no improvement, try a fuel injector cleaner with the next tank. If no improvement, then try throttle body needing cleaning, Manifold Absolute Pressure (MAF) sensor cleaning.
    #11 Mendel Leisk, Aug 18, 2018
  12. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Checked the air filter?
    If it just started a week or two ago it's too early to rule out bad gas.
    dubit and Mendel Leisk like this.
  13. Mendel Leisk
    41,792
    Premium doesn't do anything but lighten your wallet, and it's not immune from contamination.
  14. PT Guy
    1,085
    711
    "Premium" isn't premium. It merely has a higher anti-knock index which is not needed for our cars. It is no better than regular at the same station.
    Try regular gas from a different station. Give it some time to work through the system. If you picked up some water from a station, it may lay in the gasoline filter. Water removal additives can get that out of there; otherwise a new fuel filter might be needed.
