Decrease in consumption prius 2013
Discussion in 'Gen 3 Prius Fuel Economy' started by Ashraf Alzghoul, Sep 10, 2018.
  1. Ashraf Alzghoul
    Ashraf Alzghoul New Member
    jordan
    my carhas 130,000 Mile
    and before one month the cons decrease from 47---49 to 40--42???
    what is the problem???
    what i can do??
  2. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Any lights(check engine, and check hybrid system) showing on the dashboard, or the MFD?
    Any blower fan noise from the rear?
    Does the engine (ICE) run more than usual?
    Answering some of those questions, would give us an indication of what's going on?
    Dxta
  3. Ashraf Alzghoul
    jordan
    yes the engine run more than usuall??
  4. Ashraf Alzghoul
    jordan
  5. bisco
    52,096
    welcome!
    start with the 12v health, air filter, tyres pressure. did you have the major 120k service done?
    does she burn any oil? read the egr/intake cleaning threads and see dan late's oil catch can thread.
    look at nutzaboutbolts youtube videos. clean the maf.
    all the best!(y)
    Raytheeagle likes this.
  6. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    There’s no problem in fact your getting better mpgs. be glad with that many miles
    Ashraf Alzghoul likes this.
  7. Ashraf Alzghoul
    jordan
    is it necessary to change the spark plugs because i never change it
  8. Ashraf Alzghoul
    jordan
  9. bisco
    52,096
  10. Ashraf Alzghoul
    jordan
  11. fuzzy1
    10,520
    I'm suspecting some ambiguity here, between 'consumption' and 'mpg' or 'km/liter'. The offered numbers look more like mpg figures, but I hope Ashraf can clarify before we say that decrease is good or bad.
  12. bisco
    52,096
    yes
    quantumy likes this.
  13. Mendel Leisk
    41,645
    What are those numbers? I'm thinking miles per (US) gallon?
  14. Ashraf Alzghoul
    jordan
    yes MPG
  15. Mendel Leisk
    41,645
    Roughly for the last month your fuel economy has dropped, from 48~ to 41~. That's nearly 15% drop, quite significant. A few thoughts:
    1. Have you had the brakes serviced recently? They might have messed up, causing one or more wheels to drag. You could raise the rear of the vehicle in particular, verify the wheels rotate semi-freely with a good push.
    2. Have you had an oil change recently, presuming not Do-It-Yourself? Maybe the oil was changed with a heavier/thicker grade? Check with whoever's doing the service, what grade they used. I think in hotter countries they do tend to go up to 5W30 (North America is 0W20).
    3. Do you normally set tire pressures higher? Maybe they were lowered by a service department recently? Might just be a slow leak too: just check all the tire pressures.
    4. How long since you refilled the gas tank? Maybe you've got bad gas, the last fill up?
    5. Are you still on the original 12 volt battery? Have you ever left lights on when the car's parked, needed a jump start or recharge? Can you check the battery voltage, say with a digital volt meter, when the car is off and has sat overnight?
    quantumy and padroo like this.
  16. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Instead of asking questions, please let us help by answering questions from this stickie on top section of this forum:
    Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat
    Please copy and paste each and every single question here and give us answers on all of them, so we can better help you finding out what is wrong.;)
    jerrymildred, Raytheeagle and Grit like this.
  17. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Just going by the thread subject; "decrease in consumption" meaning less engine oil is being burnt.
    RMB likes this.
  18. fuzzy1
    10,520
    In most non-U.S. markets, where fuel economy is expressed in terms liters per 100km instead of US MPGs, I take that title wording as a decrease in fuel consumption.
    RMB and Mendel Leisk like this.
  19. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    It does say consumption, fuel consumption that is, in Gen 3 Prius...
  20. quantumy
    quantumy Member
    55
    37
    Could also be something as simple as colder weather, change in driving style, traffic,... Did you just buy the car and are you comparing to the previous driver? Are you doing more stop and go driving? Are you making frequent short trips where the car is turned off and on repeatedly? Elevation changes? Are you doing more city driving than highway?
    Also as everyone else pointed, if none of those are changing, then suspect some maintenance is required. Could be air filters clogged from dust, tire inflation, poor alignment (driving on potholes, bumpy roads, or dirt roads can do that), could be you need an oil change, it could be a lot of things so you have to be specific if you want more guidance.
