12v battery questions
Discussion in 'Gen 2 Prius Main Forum' started by Laura G., Sep 18, 2018.
  1. Laura G.
    Laura G. Junior Member
    My 12v triggers HUM alerts, a couple of times a week: your battery is yellow, your battery is red. I bring up the diagnostic screen, and it looks normal. Only once, was there a problem, and the diagnostic said 9.9. But after I drove it for 30 minutes, it was 14.2 again.
    I understand that unlike the battery in my old TR, there is no maintenance to be done on these. I was thinking I needed to check fluid level, and it would be fine.
    So, now I'm looking for a battery. One place asked me if the car was keyless entry. Its not. He only had a battery for the keyless.
    My question is: are they different batteries? When I look up batteries online, there's no question about keyless. Why couldn't I use that battery in my Prius? I'm starting to worry that I won't be able to get a battery, if I can't use the same for keyless. (The only other one I found in town was also for keyless.) It'll take at least 2 weeks to get one from Honolulu- if they have one.
    Please advise, in all your Prius wisdom.
  2. ChapmanF
    18,056
    What do you mean by a "HUM alert"?
    In at least some generations of Prius, there were models with and without keyless (smart key) entry. The ones with use more power from the battery all the while they are off (they are continually powering a radio to find out if you are nearby with a key), so they were fitted with a higher-capacity battery.
    It would not hurt anything to put the higher-capacity battery in your car, if it comes to that. The question would be, would it directly fit, or would you need also (one time) to pick up the tray and hold-down that were used on the larger-battery model.
    -Chap
    kenoarto and Laura G. like this.
  3. Laura G.
    Thanks.
  4. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    The battery for keyless is bigger and has 45 Ah and the other only 35 Ah.
    The bigger battery should fit in every Prius. But the part, that is holding the battery, is in cars without the keyless system about an inch smaller and must be replaced, too, when installing a bigger battery.
  5. bisco
    51,832
    what year and model car are you driving?
  6. Laura G.
    Thanks for the help. I found a local battery shop, where they knew the guy I bought my Prius from. And they were great! Got my battery replaced, $195 installed. I'm happy!
    Next up- tune up!
  7. bisco
    51,832
    congrats!(y)
  8. Mendel Leisk
    41,295
    Just curious about HUM, it's some sort of driver monitor device, emergency alert, and so on:
    Verizon's Hum connected car gadget is now a teen driver's worst nightmare - The Verge
    Verizon Hum - Wikipedia
    The actual name is "Hum", even reading through wiki a bit I'm not sure what it stands for. Just a word, not an acronym?
    #8 Mendel Leisk, Sep 20, 2018
    kenoarto likes this.
  9. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    9.9? I betcha your 12v is dead. Are you testing it using the Prius' computer after a
    full night's rest?
