Battery models compatibility
Discussion in 'Gen 3 Prius Technical Discussion' started by Andres V, Sep 27, 2018.
  1. Andres V
    Andres V Member
    71
    34
    Queretaro, Mexico
    Hi.
    I'm soon to change my Prius 2010 hybrid battery.
    My only option where I live is to get one from another trashed car.
    Do you know what models of Prius have batteries compatible with my 2010 model?
    Before buying it, is there any test I can do to check if the battery is in good shape or how long will it last?
    Thanks.
    JATURAWIT DAENGTEETA likes this.
  2. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Buying another from a trashed car? Does the instrument cluster comes on, so you could read the mileage on the car? That would give you some info.
    When you open up the trunk, take a look at the battery cover, and module serial number, then try decoding those. I'd they are older modules, and if the pack has being tempered with, you'd know.
    Finally, you would only know if its OK, when its installed on the car. If you got a tech stream software, that should enabled you read life data of the state of the battery while you carry out further tests.
    Hope this helps.
    Prieth, Raytheeagle and jerrymildred like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Good tips from @Dxta.
    Anything from 2010 to 2015 will be a direct replacement. Everything else being equal, the newer, the better.
    Beyond that, there are NiMH batteries in some of the 4th generation. Those would be trim 1 and trim 2 non-ECO, I believe. You can take the cells from those and put them in your battery. You can do the same with 2nd generation (2004-2009), but those are so old they wouldn't be worth it.
    Welcome to Prius Chat, by the way. I looked up your area. It looks like a beautiful place.
  4. Andres V
    Andres V Member
    71
    34
    Queretaro, Mexico
    Is there an significant check I can do with a Voltmeter on this new battery? Any value I should be looking for to see if it's any good?
  5. jerrymildred
    11,517
    14,157
    Tampa, FL
    You would need to load test it. More complex than just a static voltage measurement. Just measuring volts would be almost meaningless.
  6. Andres V
    Andres V Member
    71
    34
    Queretaro, Mexico
    What if I do the repair and change the defective cell/s myself. I'm seeing most of the video guides around people just checking the voltage per each cell. Isn't that enough?
  7. jerrymildred
    11,517
    14,157
    Tampa, FL
    Not if you really want to know the capacity of the cell or module. I'm not an expert, but there are some really proficient rebuilders here, so I'd do a search for the topic. There are probably several ways you could phrase the search because we must have several hundred discussions about it.
  8. Andres V
    Andres V Member
    71
    34
    Queretaro, Mexico
    I'm trying to investigate importing a rebuilt battery from the US. For this I need the exact specifications. I found the composition, power and everything but I cannot find anywhere, the definitive specifications for my Prius 2010 battery weight and dimensions, neither for other models.
    I just found on this forum something about 100lb but it's not certain.
    Does anybody know where I can find them?
  9. jerrymildred
    11,517
    14,157
    Tampa, FL
    A Gen 2 battery is about 83 pounds. I would think the Gen 3 would be very nearly the same.
    Not to turn this into a thread about the pros and cons of rebuilt batteries, but are you aware that new batteries don't cost much more than rebuilt, but the last a lot longer?
  10. Andres V
    Andres V Member
    71
    34
    Queretaro, Mexico
    You mean buying it directly from Toyota or does anybody else sells them?
    Most of the companies I found just rebuild them.
    I have a quote for a new Toyota battery here in Queretaro and it's almost double the cost of any rebuilt battery in the US. I didn't know that, I'd like to find some quote, could you suggest me someone who sells them other than Toyota? Thanks.
  11. jerrymildred
    11,517
    14,157
    Tampa, FL
    First, different Toyota dealers have different prices, so shop around. Also some will not sell over the counter -- they insist on installing it themselves. But, even if the new battery costs twice as much, it's still a better deal than almost any rebuilt one because it'll last at least five times longer unless you get one that was meticulously rebuilt and reconditioned and have good luck with the modules that were not replaced.
    Perhaps check with Matt at @Texas Hybrid Batteries (Texas Prius Battery Replacement). He has good prices, but I don't know about how you'd get the battery from him. Maybe you guys could work out something.
    Another possibility is @2k1Toaster who sells a 3rd party compatible module. He can sell you a full set of modules that you can install yourself.
    Both of these guys have a lot of respect around here. There are others, I think who can help like @ericbecky, but Matt is the closest to you.
  12. Michael Kent Handy
    Michael Kent Handy Junior Member
    60
    Fort Worth, Texas
    I think Texas Hybrid is in Austin. Is this better than the LQK in Burleson(28 miles) They may have some good used ones, but don't know how long they have been sitting. Price is just over 1,000 and if needed I can use my refurbish cylcle equipment. What do you know about quality and price at Texas Hybrid?
  13. bisco
    52,263
    Every report has been excellent
  14. Hasib
    Hasib Junior Member
    Kabul
    Sir Can I use 2019 hybrid battery pack on my 2010 prius?
  15. Mr. F
    Mr. F Active Member
    389
    263
    Washington
    It would have to be an AWD version of the 2019 since only those used NiMH modules.
    Looking at the diagrams, it also does not seem like the entire assembly would be physically compatible with a 2010. The best you could do is transplant the modules, but only from an AWD Prius.
    #15 Mr. F, Jan 1, 2024
    jerrymildred likes this.
  16. jerrymildred
    11,517
    14,157
    Tampa, FL
    What @Mr. F said. Also, you can't just put in the pack because the cases are totally different. You need to transplant all the modules from the new battery to the old one.
  17. Kiwibird
    Kiwibird Junior Member
    56
    Sydney
    i-Tech
    Ist possible to replace the low voltage bad cells (as shown on Dr.Hybrid app) with a good cells and leave the other good cells?
  18. bisco
    52,263
    yes, but you should balance everything for best results. search here for many good threads with rebuilding advice
    Kiwibird likes this.
  19. Kiwibird
    56
    Sydney
    i-Tech
    Balancing means make all cells same level of voltage before re-installing in car you mean?
  20. bisco
    52,263
    similar, and also rejuvenates the cells by charging and discharging
