1. David E. Edwards
    David E. Edwards Junior Member
    25
    Sugar Land, TX
    Has anyone had any experience with this company? They make automotive fluid products like brake fluid, transmission fluid, anti-freeze, and various fuel additives.
    Most items are available only at local auto repair shops.
    What makes them interesting is that if you use their products and change at 30,000 miles for the transmission fluid they offer a life-time warranty of $4000 to repair if needed.
  2. FingerLakePrius
    FingerLakePrius New Member
    Auburn, NY
    2018 Prius
    Keep us posted
    FingerLakePrius
  3. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Yes, I've recently used one of their products.
    No, I've never used their warranty service before as my mileage and product usage would preclude me from doing so.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I’ve used 44k, EPR, moa as well as Extended Life moa. They work well;).
    EPR gets a lot of deposits out and MOA’s keep the oil basic, which is key as the engine ages as tolerances will grow and gas will get into the oil and make it slightly acidic which can then attack the rubber parts.
    Never used them early enough in the cars life though to know about warranties ;).
  5. Tideland Prius
    16,536
    My local dealer uses them if your car is out of warranty. I haven't noticed anything different. They've been using their products on my car for 2-3 years now. They offer (free) roadside assistance too if you sign up after servicing with their products.
  6. Elektroingenieur
    2,515
    3,282
    Three Touring
    I’d read BG’s program terms carefully before assuming that’s true. Note that the covered “Transmission Service” requires the use not only of a BG transmission fluid but also of “BG 106 and 310,” their cleaner and conditioner. The repair coverage excludes “electrical components” and also allows the use of “replaced parts of like kind and quality”; for a costly claim, I’d expect their third-party administrator to interpret these provisions strictly.
    Toyota specifies the use of only Toyota Genuine ATF WS transmission fluid; see page 729 of the Owner’s Manual (PDF) for 2017, for example. For engine oil, coolant, and brake fluid, Toyota acknowledges that third-party products meeting the specifications may be used, but no such statement appears about transmission fluid.
    Even if you accept BG’s claim that their BG Low Viscosity Full Synthetic ATF (315) “meets or exceeds the performance criteria of...Toyota WS,” the same cannot be said of the BG cleaner or conditioner, without which there is no coverage from BG. In my opinion, Toyota would be within their rights to deny a claim under the hybrid system warranty for a failure in a transaxle into which such a foreign substance (i.e., anything other than ATF WS) had been introduced.
    I have no brand preference for engine oil, but I also wouldn’t use BG’s 0W-20 oil in a Prius car. It may be a fine product, but BG doesn’t say it complies with the ILSAC GF-5 standard specified by Toyota (explained in my previous posting), nor is it listed in the American Petroleum Institute’s EOLCS directory.
    Tideland Prius and SFO like this.
  7. yeldogt
    yeldogt Active Member
    810
    313
    NE
    BG makes various service machines for fluid changes -- I'm not sure how the various manufacturers view the fluid products when cars are under warranty. I know my local Jaguar dealer will use the BG machines for coolant and brake fluid when doing a full flushes after cars are out of warranty. The brake fluid needs to be changed out every two years. Frankly -- it's a money maker for the dealers ... with proper refresh you don't need or want flushes.
  8. PriuSocal
    PriuSocal Member
    202
    40
    SoCal
    I recently got a deal on BG 3143 (3 gal) ATF which I am trying to confirm if in fact it works instead of the ATF WS Toyota uses. I got it from a Lexus tech that said they use it on all their cars requiring WS at the dealer. I am wondering if anyone else here has used it.
    I am planning on using this on my 2008 Prius AFT fluid change. Not that I am cheaping out or anything it’s just that i got the 3 Gal tub of sealed BG 3143 for $80 which would be good for at least 3 ATF fluid changes.
  9. Mendel Leisk
    41,165
    Just my 2 cents: I’d sell (or just recycle) that deal, not worth it. The Prius transaxle ATF WS spec’d by Toyota (in owners manual) is the one time they get totally adamant, saying anything else could cause damage.
    it could be hyperbole but why chance it?
    Tande likes this.
