Misfire detected- P0300 p0303 set
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Megadeus, Mar 3, 2012.
  1. Baz2473
    Baz2473 Junior Member
    37
    Kent. England.
    Ahhh I see. Ok. Thanks for the tip. Did wonder what you were getting at.
  2. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Poor compression will cause a misfire on that cylinder but it's easy to check with a compression test.
    Compression Test | PriusChat
    Main bearing issues should cause random misfires (ie misfire code jumps around P0301-P0304)
    I would still try a new injector on cylinder #3 (still my bet for what is wrong) long before condemning the engine for good.
    #22 MTL_hihy, Feb 15, 2015
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    230,000 miles. Many low oil incidents.
  4. MTL_hihy
    536
    261
    Maritimes, Canada
    Running an engine low on oil or having high mileage does not mean it is toast......car in the video sounds done too but it was perfectly fine.
    How would you explain the misfire not jumping around to random cylinders if the bottom end was gone?
  5. Baz2473
    37
    Kent. England.
    What was wrong with the Prius in the video? Was it just an injector? Because that's exactly how mine sounds until you accelorate.
  6. MTL_hihy
    536
    261
    Maritimes, Canada
    Yes, it was only a bad fuel injector.
  7. Baz2473
    37
    Kent. England.
    Thanks for the help guys. But I've now gone and purchased a 2015 Prius. Gonna sell the old one. Can't be bothered trying to diagnose it any longer. Not only that I reckon with the current mileage and problem I reckon there will be more problems to follow.
    Loving the new T-Spirit. The LED headlights are AMAZING. Don't know how I ever lived without them.
  8. MTL_hihy
    536
    261
    Maritimes, Canada
    You'll still need to fix that injector to sell it but yes older vehicles will usually have more issues than newer ones.
  9. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    if there is coolant on the dipstick, forget the injector. engine is toast.
  10. Steve Morris
    Steve Morris Junior Member
    Melbourne
    ----Australia----
    Water in the oil as well as the engine is misfiring, to me it sounds like a blown head gasket......
