Fuel gauge , speedometer dot display anymore
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Naushi Hussain, Oct 20, 2018.
  1. Naushi Hussain
    Naushi Hussain Junior Member
    Fountain HIlls AZ
    I brought my Prius 2010 to car wash and after wash I found out the fuel gauge, speedometer and MPG are not displaying any more. Hybrid piece on the right shows OK.
  2. Mendel Leisk
    41,900
    One side of the display is actually projected from below. May or may not be the case, but verify there's nothing sitting in there, covering the projector, say a business card, something like that.
  3. Naushi Hussain
    Fountain HIlls AZ
    Appreciate the tip but I checked and found nothing. The energy monitor and clock display well but nothing on the left side. I am driving without knowing what speed I am driving at. - Could it be the fuse ?
  4. bisco
    52,386
    more likely a bad multi function display, although the 12v can sometimes cause this condition. check the voltage at the jump point in the morning before starting the car
  5. Chuba
    Chuba Junior Member
    45
    Nigeria
    Pls I have this same issue now
    Left side of my display that is projected is nolonger working after cleaning it. Nothing is covering it. I think is water damaged. How do I fix it?
  6. Mendel Leisk
    41,900
    Sorry no ideas, but maybe others do.
  7. Chuba
    Chuba Junior Member
    45
    Nigeria
    I have finally fixed it.
    I removed the dashboard. Removed the speedometer Cluster then removed the flex of the projector. Cleaned the flex and reinstalled every thing back. The projector started working well
    burrito and Mendel Leisk like this.
  8. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    (y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)
  9. ChapmanF
    18,538
    By 'flex', you mean something like an FPC connection to the projector circuit board?
    or something else?
