Unlocking hatchback with fob in pocket
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by pbasch, Oct 31, 2018.
  1. pbasch
    pbasch Junior Member
    40
    Los Angeles
    2018 Prius Prime
    My old plug-in Prius did this - with fob in pocket, I could unlock back door by pressing rubber latch. My 2018 Prime Plus doesn't do that. I have to either unlock by touching driver's door handle, or press unlock on the fob twice.
    Is there a setting, or they just don't do that anymore?
  2. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Mine operates as you want it to.
    No need to unlock anything prior as long as I have the FOB.
    But I have the Advanced trim.
    #2 schja01, Nov 1, 2018
  3. KP7
    KP7 Member
    43
    New England
    2018 Prius Prime
    Plus trim only has driver door fob proximity unlock. Not sure if you could pay the dealer to upgrade assuming that it is just a software feature.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Yap, Premium and Advanced trims have 3 door SKS, but Plus is only drivers door SKS. I think I saw some Gen3? hack thread on this topic, but not sure if anyone succeed. Even if it is possible, I would think it is going to be fairly expensive and/or complicated upgrade.
  5. bisco
    52,386
    There is another thread with the plus upgrade question, but no answer. I think it is next to impossible
  6. schja01
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    I was wondering if the metal bracket above the hatch release that has been reported as rusting
    might be an antenna component?
    Is the "Plus" trim bracket plastic?
  7. pbasch
    40
    Los Angeles
    2018 Prius Prime
  8. bisco
    52,386
    That’s the usuall answer:p
  9. Hidyho
    Hidyho Senior Member
    2,699
    531
    2018 Prius
    schja01 likes this.
  10. bisco
    52,386
    Thank you for your kind words!(y)
    Raytheeagle likes this.
