Heart Transplant at 278,000 miles
Discussion in 'Gen 2 Prius Main Forum' started by SnT08Prius, Jun 22, 2018.
  1. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I thought of that myself. 100 ft lbs is a lot of torque, and those bolts are under a lot to stress. The heads are begging to pop off at that torque.
  2. hill
    8,885
    When you said "stripped", it 1st sounded like the threads were gone, but now it sounds like you really meant rounded. Okay. Other ideas from a 3 decades Aerospace Machinist. After the rounded bolt has been thoroughly soaked with a penetrant/fluid if there's room, use a little angle grinder to make your hex a little smaller, then use the next size or 2 down socket with breaker bar. Or, what's sure-fire, is to heliarc a big as practical peace of Steel onto the top of the rounded hex - then you have a decent way to grab ahold - with an open- end wrench or whatever. Plus, a lot of time, the weld Heat will significantly help with loosening a frozen Bolt.
  3. Skibob
    2,912
    1,505
    Northern California
    It’s a rounded Allen key. What would the procedure be for that?
  4. hill
    8,885
    Same thing. Heliarc a Allen wrench into the round out out hole & you'll be good to go. That way you'll actually be able to put 2 wrenches box, ratchet, whatever on it (one on top of the other) - turning & pulling like they're a T-handle.
    Here, just took a picture
    #44 hill, Nov 19, 2018
  5. Skibob
    2,912
    1,505
    Northern California
    I like it, but I think the OP is looking for something a little less high tech. Like stone knife and bearskin simple.
  6. SnT08Prius
    SnT08Prius Active Member
    158
    187
    Bozeman, Montana
    The issue is the head bolt is deep inside the the cast and there is no way to get a grinder in there. Welder is not available at this point.
    I did get the bolts (2) to do the first crack and then they rounded off. Having worked on many engines over the years from the 4 cly, 6 and 8's I know the meaning of a shagged bolt - theses are shagged 100% sure of it. I did try jamming feeler gauges in and hammering the allen shaft into the bugger. It just split the high grade steal lol... when I put the breaker bar on it.
    So I will go with what I have and thats the drill and some quality tipped drill bits - seeing as the bolts are rounded already :)
    If I kill it off so be it. I have plenty of parts to fit into the next oil burner/clatter case Prius motor! Plus all the photos to come will be worth it! :)
    edthefox5 likes this.
  7. Mendel Leisk
    41,789
    I know hindsight is 20/20, but moral of the story is get the right tool?
    Skibob likes this.
  8. SnT08Prius
    158
    187
    Bozeman, Montana
    Yeah - It was an all angle tool bit I first used.... I really thought I had id done at first - but no it needed 2 cracks to undo!
    I got the right tool in the end and that worked on the others... just! Funny thing is the crank pulley came of easy and I was expecting that to be hard...
    edthefox5 and Mendel Leisk like this.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    SN please explain the rope in the cylinder trick I have never seen that before.
    Thanks.
  10. edthefox5
    10,096
    4,834
    Clearwater, Florida
    I like hills suggestion. Couple that with my impact gun gimmick and it will come out.
    It may take 30 mins of bumping the impact gun but eventually it will come loose.
    Patience.
  11. hill
    8,885
    Iirc, he's already drilled them out instead.
  12. SnT08Prius
    158
    187
    Bozeman, Montana
    The rope in the cylinder is a soft fill of the combustion chamber that the piston stops on allowing you to crack the crank bolt undone. The rope then pulls out with no damage to piston or valves.
  13. Skibob
    2,912
    1,505
    Northern California
    When I was changing the clutch on my wife’s 4 Runner I broke off 2 exhaust studs on the drivers side exhaust manifold. I tried a stud extractor first and broke them both. Then i removed the manifold and tried welding bolts to the studs. No joy. Wound up having to drill them out. Sometimes the hard way is the only way. At least I had the option of removing that exhaust manifold.
    SnT08Prius and Mendel Leisk like this.
  14. Mendel Leisk
    41,789
    Another tack: Eric the Car Guy uses torching here:
  15. SnT08Prius
    158
    187
    Bozeman, Montana
    So the head bolts drilled out just fine with small battery drill and some quality drill bits.
    A broken oil ring was the issue.. mashed up the piston and head a little.
    Crank looks fine.
    prius-07, m.wynn, Skibob and 3 others like this.
  16. Patrick Wong
    18,210
    6,511
    Great photos, very interesting to see how much carbon accumulated at 278K miles.
    Did you have a chance to look at the camshafts to see what wear was present on the bearing surfaces and the cam lobes?
  17. Skibob
    2,912
    1,505
    Northern California
    How does the bore in that cylinder look?
  18. SnT08Prius
    158
    187
    Bozeman, Montana
    The bore looks great and still has cross hatch marks and almost no ridge to speak of. I think a quick hone and new rings and bearings will do just nicely to have a short motor ready to go. (and a replacement piston)
  19. SnT08Prius
    158
    187
    Bozeman, Montana
    The camshaft bearings all looked very clean. The only bearing in the whole motor to have a score mark was 1 shell of No 3 main cap.
    I will do detailed photos in the next week or so with proper digital camera of all the parts. Seems not many motor pulled apart at this sort of miles for others to see.
  20. SnT08Prius
    158
    187
    Bozeman, Montana
    Cleaned up the pistons this weekend.
    Raytheeagle and SFO like this.
