Electrical add ons
Discussion in 'Gen 3 Prius Accessories and Modifications' started by scotttyb68, Nov 30, 2018.
  1. scotttyb68
    scotttyb68 Junior Member
    25
    michigan
    Finally purchased the 2015 Prius that I've been Leasing. One of the things that annoyed me about my old 2008 and this one is the lack of convenient power sources. There's basically no outlet for your passengers in the back seat and there's no outlets for anything in the trunk area if you wanted to use a small tire pump or something for example. Is it hard to put in new power outlets? And is it expensive because I sure as heck I'm not going to start ripping up on this car it's not like the old days. I've never understood why the Japanese who are Tech mad have paid so little attention to this particular part of the Prius. My wife has a Traverse and it has access in the front seats then there's plugs for the middle row and the back seat and in the back back.
  2. padroo
    padroo Senior Member
    2,763
    2,252
    It would be very simple to just tap the 12V battery with the proper size wire and fuse and install more power points but they would be live all the time and if you left something plugged in it would kill your battery. The ideal way is a little harder is to find a way to power it only with the key on. This would be a little more difficult but not impossible.
  3. scotttyb68
    25
    michigan
    Thanks yeah, I know that the Prius battery is very small and so I would want it to work like all the other ports. They definitely would need to turn off. Are there shops that do this kind of work or is it something I would have to do it myself? Because I really don't think I should do it myself I'm not real good with electricity and especially on a car this complex I just wouldn't dare. The other thing is if I added those sort of things would it void my warranty and some way? I appreciate your quick response to my question thank you very much.
  4. scotttyb68
    25
    michigan
    Also I was wondering how difficult it would be or if it even can be done to make the door locks all unlock when you approach the car. My 2008 and had that you could go up to the front doors or the hatch and everything would unlock and this one only a driver side door unlocks which is not end of the world but it is annoying. I was wondering if anybody else has modified their Prius to be able to have all doors unlock.
  5. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    Check customization in the user's manual or Google your question. I changed the default so all doors unlock on my 2013, but I forgot what I did.
    scotttyb68 likes this.
  6. PriusCamper
    PriusCamper Senior Member
    12,985
    5,281
    Pacific Northwest, USA
    Well... Modern car interiors are designed in ways that makes taking them apart very simple, not very challenging... For less than $20 and your own labor you could install some 12v and USB ports in a couple hours. For $100 or less you could connect a power inverter to the 12v battery and have 110v power too, which Prius owners sometimes do to power a small amount of their home during power outages.
    And if you don't have the skills or don't want to learn them any car stereo installation business will professionally do the work for you in the $200-$600 range depending on what your needs are...
  7. ChapmanF
    18,454
    It's not hard to build an aux-power distribution thingy using a gizmo like the InPower VCM-06 to turn it on and off. You don't need to find specific switched circuits to tap into; the VCM just recognizes the voltage difference between when the car is READY and when it isn't.
    That was the Gen 3 reimplementation of the original Gen 1 thingy.
    -Chap
    scotttyb68 and Robert Holt like this.
  8. PriusCamper
    12,985
    5,281
    Wow... That's a pretty extreme rig... Just looked at 'em on Ebay... Back in my Campervan building and car stereo installing years in late 80's thru early 90's I would of never imagined something so fancy. You could do alot of pushing the limits of what a Prius is capable of with gear like that.
  9. Djjkarate
    Djjkarate Member
    96
    47
    Pacific Northwest
    FYI... I bought a cigarette lighter extension cord off ebay for under 20 bucks.. you can just run that down the middle of the car between the seats...
  10. scotttyb68
    25
    michigan
    Cool. I can do that, thanks.
  11. ChapmanF
    18,454
    All comes down to your application. Each of the existing power outlets is rated ten amps. If you want to power some things that won't ever need more than ten amps together (either they add up to less than ten, or they're individually less and you know you'll never use them together, or so on), an extension cord sharing one car outlet is the simplest solution and completely does the trick.
    It's only if you want to run things that draw more current than that, or just too many things, that an extra power distribution gizmo becomes useful.
    -Chap
  12. Slider2732
    Slider2732 Member
    64
    66
    Arkansas
    Just reading this, I noticed the lock thing hadn't been addressed.
    Am not sure if all Gen III do it but...
    Simply sit in the car and press both the lock and unlock buttons together on the key, for about 5 seconds. The car will beep and you should see the red car icon on the dash change to all doors open.
    Now, when you approach the drivers door, all will open.
    If you go to the rear hatch, it will open from locked too, handy for shopping trips.
  13. scotttyb68
    25
    michigan
    Yes I have set it up to unlock 3 doors at once when you open the drivers door first. I could swear on my 2008 Prius that I could walk up to driver passenger or rear hatch and they'd unlock the rest. So I could walk up to the hatch and with key in pocket, I could reach for the handle and it would unlock the hatch and the doors. Now in my 2015 Prius I always have to go to the drivers door first to get all 3 to unlock then play ring around the Prius to whatever door I really need. I like to open the passenger door for my wife, and I could just walk to the passenger door on the '08 and all would unlock and I could open her door. Now I have to go to the drivers door and open it then she just climbs in. Unless I fumble for the key and unlock it manually. But that defeats the purpose of keyless entry.
  14. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    I suppose you first leased and purchased your 2015 Prius Two? Because what your are describing is you have a driver door Smart Key System vs you want a three door SKS where you can just walk up to passenger door to unlock and open.
    Oh by the way, keyless entry basically means you don't need to use your key to enter/unlock the doors, doesn't mean you don't need to hit any buttons on the remote fob. :whistle:
  15. Slider2732
    Slider2732 Member
    64
    66
    Arkansas
    I know i've RTDM'd out the wazoo and still get problems.
    Or, to translate, have read the manual several times and still have some confusions about the doors.
    For example. We get home from shopping and my wife has the key. I run around the back to open the hatch and the door won't open. By which point, she's out of the car and closed her door, so I go back to the passenger side to press the unlock button on that door. The hatch opens!
    So, back at the store, when she walks up with the full shopping cart, all the doors unlock. I also get in by simply opening the passenger side door....how on earth is the hatch not unlocked when we stop in the driveway?
    The hatch will open fine if she gets out and walks to the back instead of myself. The 3ft proximity thing with the key seems to be in effect.
    Shouldn't all doors stay open until she locks the car with a front door handle or the trunk button or keyfob?
    Bizarrely again, we both can get out, but the one without the key can lock the car from the other sides door handle sensor. Both doors must share that circuit, because we're not standing just 3ft apart.
    The solution, is to come up with lots of deft sneaky similar methods with electronics to make her do all the work :)
  16. scotttyb68
    25
    michigan
    Can you have a SKS installed or not?
