Unknown dangling button thingy
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by pokenoprius, Nov 27, 2018.
  1. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    Hi all, in my 2013 plug in, I have this funny dangling button thing, the cut out on the plastic looks like it was designed for it so I suppose it’s from the factory . Anyone know what it is for? I have Pressed it down I have held it down I’ve done everything with that but nothing happens , thanks all.
  2. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    Photo :)
    Raytheeagle likes this.
  3. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    It is right beside the window wiper control stalk
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    After market car alarm?
  5. padroo
    padroo Senior Member
    2,763
    2,252
    Looks like it was added on. What happens when you press it?
  6. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    I’m not sure , If it was a kill switch , I suppose it wouldn’t be in such a public space
  7. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    It’s not like anything we have in the states;).
    So unless there are factory options over there, my bet is someone added it, whatever it is(y).
  8. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    Nothing happens at all. There is no writing on the cable nor is there any writing behind the button.
  9. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Pull the plastic shroud around the steering wheel and see where the wires go ;).
    They’ll go somewhere and will help with next steps (y).
    jerrymildred and pokenoprius like this.
  10. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    GPS dongle? I drive part-time for a local courier-service, and all the firm's cars are equipped with GPS dongles, and driver-ident alarms! (…just sayin' ;))
    pokenoprius and Raytheeagle like this.
  11. fuzzy1
    10,603
    That looks very after-market to me. The factory shouldn't be making any thingies dangling on any wires, the wires should be fully hidden behind plastic panels.
    #11 fuzzy1, Nov 28, 2018
    The Electric Me and Raytheeagle like this.
  12. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    Yea I’ll draw up the courage to take the cover off and not break anything lol
  13. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    I’m wondering if it might be a button for the factory Head unit which has been taken out, Because I think I just found the microphone
  14. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    Mic?
  15. bisco
    52,419
    doesn't look factory at all to me. maybe for the aftermarket h/u
  16. bluemanalbert
    bluemanalbert Junior Member
    40
    22
    visalia, CA
    Seems to have a mic in there.
    be well
  17. kenmce
    kenmce High Voltage Member
    1,551
    524
    NY
    1.) The dangly bit is where a previous owner added an on/off switch for something. Can't say what.
    2.) If that is a mike, down by your feet is a staggeringly bad place for it.
    3.) If you really need to know, you'll have to chase wires.
    4.) Otherwise, just drive.
  18. enr
    enr Junior Member
    I would first guess a wired Bluetooth interface similar to this one.[​IMG]
    Second guess would be a wired GPS antenna. It would be a bad place for one, but then again they put the mic under the dash instead of running it up the A pillar to a common spot over the sun visor.
  19. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Yeah it's probably something related to an aftermarket headunit/satnav system, 100% not OEM!
  20. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I have no idea.
    But the speculation is fantastic.
    jerrymildred likes this.
