Hey I'm brand new here. Need some help!
Discussion in 'Gen 2 Prius Main Forum' started by Gat, Nov 26, 2018.
  1. bisco
    51,255
    ugly
  2. Gat
    Gat Junior Member
    31
    Oregon
    Alright so last night I pulled and cleaned the DS O2 sensor.
    I ordered this before I found this page : Panlong Bluetooth OBD2 OBDII Car...
    To use in conjunction with the "DR. Prius" app....was this a waste of money? Can I screw up my car by using it to view and clear codes?
  3. Mendel Leisk
    40,687
    I'd second that; the search function within PriusChat is not as good, and it's buggy: first search will often yield nothing, and a repeat of the same phrase works, but not that well. Just search with Google for "priuschat...".
  4. Mendel Leisk
    40,687
    Is that part of the air filter gasket?
  5. Gat
    Gat Junior Member
    31
    Oregon
    I dont think so? The new filter had a full rubber surround on it to the adjacent side.
  6. Gat
    Gat Junior Member
    31
    Oregon
    You guys have any opinions about that OB2 scanner I posted?
  7. bisco
    51,255
    never heard of it, but it can't screw up your car. don't leave it connected though
  8. Gat
    Gat Junior Member
    31
    Oregon
    Car stalled out this morning and gave me the RToD.
    After a few minutes it started back up. With the light still on.
    It's currently throwing a POA08 code.
    No idea where or how to start.
    I found a thread talking about "P0A80" reversed 8 and 0....and it was talking about a full HV battery replacement.
  9. davecook89t
    davecook89t Senior Member
    1,076
    810
    Washington State, Florida
    Four Touring
    My list of codes shows P0A08 as "DC/DC Converter Status Circuit", which is a component of the inverter. At this point, you may want to perform the self-test shown in the following video:
    You should see about 14.4V on the auxiliary battery with the Ignition On. If you see something other than that, that would confirm that you have a problem with the DC/DC Converter, which unfortunately means you need a new (or used) inverter.
    PriusCamper likes this.
  10. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Starting at 15:05 to 18:02 discusses the board you would need to get replaced.
    davecook89t likes this.
  11. Gat
    Gat Junior Member
    31
    Oregon
    Why can't I see the video? It just shows a picture that I can't click a link or anything
  12. Gat
    Gat Junior Member
    31
    Oregon
    It's showing 14.0v even.
    Is there anything I can check or replace without taking that kind of a hit?
  13. Gat
    Gat Junior Member
    31
    Oregon
    Sorry....I misspoke...with the in accessory mode like the video shows it's at 12.6v
  14. bisco
    51,255
    is there movement in the inverter pump reservoir?
    Raytheeagle likes this.
  15. Gat
    Gat Junior Member
    31
    Oregon
    In accessory or while the car is turned on?
  16. bisco
    51,255
    on, not sure if it runs in acc or not
  17. Gat
    Gat Junior Member
    31
    Oregon
    I see little swirls, flickers of something moving.
    SFO likes this.
  18. Gat
    Gat Junior Member
    31
    Oregon
    I cleared the codes, could that have something to do with it?
  19. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    If the 12.6 volts is after sitting over night before you ever put it in Ready, that is a healthy battery.
    If it jumps by a volt or more when it goes in Ready, the DC to DC converter is acting right.
    Gat likes this.
  20. Gat
    Gat Junior Member
    31
    Oregon
    Ok I'll check in the morning.
    Is it possible it could be something else?
