Well, my 2010 just lost it's hybrid battery at 105K mileage
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Alphawolf, Dec 7, 2018.
  1. Alphawolf
    Alphawolf Member
    84
    36
    Northern Utah
    9 years old and 105K and the dealer quoted me about $4K for the job. I called Toyota USA and they offered nothing. The hybrid experience failed me. I saved perhaps $2000 in fuel cost over 9 years. Any recommendations where to buy a good rebuild for a DIY install? Thanks
  2. Robertto09
    Robertto09 Junior Member
    51
    Costa Rica
  3. Mendel Leisk
    41,901
    Shop around dealerships first. Isn't the going rate more like $2500~3000?
    I just dropped a grand (CDN) on new (17") tires, for comparison. Price of being mobile?
  4. davecook89t
    davecook89t Senior Member
    1,092
    826
    Washington State, Florida
    Four Touring
    There is no location in your profile, but I guess we can assume you are not in a CARB state, correct? Even if you are not, you are barely out of the warranty period, both years and mileage wise. Having a failure of the HV battery is unusual for a car that is less than 10 years old. In many cases Toyota has agreed to cover part of the cost of replacement even for a car that is out of warranty with an early failure like yours. Have you had any repairs or maintenance done at a Toyota dealer? Having an ongoing relationship with Toyota and its dealers will often swing the scales in your favor when trying to make a case for a "Goodwill Warranty". Here is a thread of others' experience with obtaining a goodwill warranty. I would want to be sure you are talking to the right people at Toyota to make your case.
    HV Battery Goodwill Warranty Listing - Toyota Prius USA | PriusChat
  5. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    You don't give your location, maybe that would help the community recommend a third-party hybrid battery installer. Failing that, try Google search for hybrid battery recondition/replace shops. You should be able to get a reconditioned battery for $1,500 installed, depending on your location of course.
    Bay Stater and Montgomery like this.
  6. frodoz737
    frodoz737 Top Wrench
    4,720
    2,517
    33
    The HV Battery is not hard to change if you are any good with a wrench. There are plenty of references, videos and some of us have the manuals if needed. You should be able to buy a new one over the counter a lot cheaper.
    Bay Stater likes this.
  7. ASRDogman
    ASRDogman Senior Member
    7,818
    3,982
    I can't remember the correct handle, but one user named "Toast" or "Toast2k" sells NEW cells for a reasonable price.
    I can't seem to remember the correct handle.. sorry
    Bay Stater and 2k1Toaster like this.
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I would definitely SKIP the remanufactured / reconditioned / used batteries especially for $1500. $1600 gets you a new battery kit shipped to your door.
  9. ASRDogman
    7,818
    3,982
    Thanks! I knew I was close to your handle. :)
  10. davecook89t
    1,092
    826
    Four Touring
    @2k1Toaster
  11. Alphawolf
    Alphawolf Member
    84
    36
    Northern Utah
    Okay sorry guys. I'm in Northern Utah. What is a "new battery kit" vs. a rebuilt battery? I've been investigating "Best Hybrid Batteries" out of Shorewood IL. They are quoting $1350 plus $140 shipping for a ready to install battery. I just take mine out and put theirs in, shipping mine back to them.
  12. Alphawolf
    Alphawolf Member
    84
    36
    Northern Utah
    How does a new battery kit work compared to one ready to install?
  13. Mendel Leisk
    41,901
    Consider the "just out of warranty" comments, and ask all the dealerships in your area for a price, if you haven't already. That's the low-hanging fruit: $4000 is too steep; maybe if you throw the question out to all dealership you'll be getting $2500~$3000 quotes for new battery, installed. Then talk directly to Toyota, they've been known to come through for 50%, in cases like this.
  14. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    Check out these OBD2 scanners.
    tachyontechtools website, under Toyota Prius. The site isnt letting me link.
    I would buy a scanner that reads battery cell voltage, find out which cell is dead or dying and replace. Getting to the cells takes time, organization and patience but is definitely doable.
  15. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    A new battery is never ready to install. Your options are my kit or Toyota. End of list. With Toyota they sell you a case with the battery modules preinstalled. But none of the ECUs or relays or anything. You have to swap those over. Then you send them back your old shell and batteries minus the electronics, aka the core or else you don't get your $1350 back. In mine you get the batteries. You take your old core and remove the old batteries. Put in the new ones and attach a new wiring harness. Kind of the opposite of the Toyota battery in terms of what's needed. Nothing to ship back. You keep your old dead cells possibly resell them.
    In a used world you're getting 28 original battery modules of similar capacity. Hopefully they've been tested, sorted, and matched to be similar. You need at least a few hundred modules to do this properly. So your fly by the night guy can't do it. There are a handful of companies that can. Ideally you want thousands and as far as I know there's only one of those companies. You're buying an unknown age and mileage mismash of modules. You may get 5 years out of it. You may get 3 months out of it. The warranty is great but you're going to be down a car and labour everytime. There really isn't a comparison between a used battery and a new battery.
  16. Alphawolf
    Alphawolf Member
    84
    36
    Northern Utah
    I called Toyota USA today and spoke with her for about 15 minutes .Ultimately I no help whatsoever was offered on the repair
  17. Alphawolf
    Alphawolf Member
    84
    36
    Northern Utah
    Thanks for the awesome explanation. How do I get in touch with you? PM?
  18. Mendel Leisk
    41,901
    That $4000 quote would very likely be fully installed, with 3 year warranty. No core charge, no hassle on your part. And: it seems very high, if you've only talked to one dealership, do yourself a favour and phone everyone within practical range.
  19. bisco
    52,390
    get the toaster for $1,600. and diy, you'll figure it out. you have a lot of life left in your car.
    be sure to clean the egr circuit before the headgasket blows. are you burning any oil?
    Bay Stater and Mendel Leisk like this.
  20. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Curious why the battery died so soon o_O
    Do you ever have pets in the car or something that might clog up the HV battery fan?
    Maybe traverse elevation on a regular basis?
    Did the dealer offer up any codes or DTCs when they gave the repair quote?
