2010 Radio Swap Out
Discussion in 'Gen 3 Prius Audio and Electronics' started by Borninblue, Dec 12, 2018.
  1. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    I am about to swap out the stock radio in my 10’. It is the basic CD player with no navigation. I know if I don’t use a certain wiring harness I will loose the radio steering wheel controls. I never use them so not concerned with them. I am concerned with using the trip and display buttons. Does anyone know if those controls will still work and I just loose the radio functions?
    The last thing is the antenna. In the old days you had to buy a factory antenna adapter to fit into the new radios...is this the case and required for the Prius as well, or is the antenna a direct plug and play into the new unit?
  2. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    You will need a antenna adapter. The display and trip function will continue to work regardless of head unit. On my '14 there was a narrow LCD screen below the radio that contained some functions that I can't remember but that screen comes out when a new head unit is installed.
