Approaching 200k mi... now what?
Discussion in 'Gen 3 Prius Main Forum' started by SonicDriver, Jan 9, 2019.
  1. SonicDriver
    SonicDriver Junior Member
    Orlando, FL
    Three Touring
    I am a ride share driver and have a Gen III 2011. I bought it used in 2015 with 64k miles and I am about to cross 200k miles. I have put nearly 40k/yr on the car, so I drive it a LOT.
    Other than fluid changes and cleaning the cylinders, I have not had any major work done on it.
    I love the car and want to keep it (it has an upgraded stereo, backup camera, leather, and DVD player).
    What should I be doing, what can I expect in regards to maintenance and upkeep? What is known about high mileage Priuses?
  2. CR94
    CR94 Senior Member
    2,734
    1,193
    Northwestern S.C.
    What do you mean by "cleaning the cylinders"?
    Zaza 13 likes this.
  3. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Brake caliper lube- every 3 years or 36,000mi. Not in manual but by the time a new PC member post seized pads and new rotors needed, it’s because of that or lack there of.
    Bay Stater, Mendel Leisk and RMB like this.
  4. bisco
    52,244
    just drive it. these cars are good for half a million miles as taxi's
    RMB likes this.
  5. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    There are many things you can do to help the car keep running and help to avoid troubles. Nutz about Boltz has many videos in the 3rd gen maintenance section that can be helpful.
    Off the cuff you mention fluids, I'll assume that includes brake fluid every 3-4 years, transaxle fluid ever 50k, coolant (engine and inverter)
    Other than that spark plugs would be something to address if not done.
    Clean the EGR tube every 50k or so
    As Grit said above lube the caliper slide pins
    Clean the hybrid battery fan.
    Bay Stater likes this.
  6. Zaza 13
    Zaza 13 Junior Member
    74
    Israel
    My prius 2012 is 340k km, feels good runs goodjust, change oil every 6k miles.
  7. Mendel Leisk
    41,792
    Yup, filters, brakes, transaxle fluid, EGR cleaning, intake manifold cleaning. Oil catch can and brake fluid change?
