Removing rounded hex
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Suprius, Jan 22, 2019.
  1. Suprius
    Suprius Junior Member
    29
    L.A, C.A
    Anyone have tips on how to remove a rounded hex drain plug?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Gonna have to drill out and retap
    Raytheeagle likes this.
  3. Robertto09
    Robertto09 Junior Member
    51
    Costa Rica
    Use oversize key allen and hit it with a hammer until it goes into the nut
  4. gliderman
    gliderman Active Member
    751
    225
    A stud remover might work.
  5. VFerdman
    VFerdman Senior Member
    1,194
    1,218
    Western Massachusetts
    Cut a slot into the bolt head and use a flat head screw driver
    Robert Holt likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    An easy-out might get it. You may have to drill a hole to get one in there, though.
    Raytheeagle and Robert Holt like this.
  7. padroo
    padroo Senior Member
    2,763
    2,252
  8. Mendel Leisk
    41,873
    What is that btw? Is it the coolant drain bolt under transaxle??
    I would try getting it out with a stud extractor, one of those drills with aggressive reserve thread. You might be able to get the stud extractor to bite sufficiently as is. If not, drill right through and (after everything drains, try again. Be as careful as possible, to stop drilling just as you get through, try to complete it with the stud extractor bit.
    Before getting into it, buy the replacement bolt. Don't get fancy, just get one from the dealership, make sure you've got the right one.
    You know, open letter to Toyota: why oh why do you use hex sockets on the drain bolts. How about 3/8" square holes? I know that's all I've ever seen on Hondas, never a problem.
    padroo likes this.
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,963
    New England
    Bolt extractor might work.
  10. Mendel Leisk
    41,873
    That's brilliant!
    Yeah, looks to be the transaxle coolant drain bolt, probably the same drain bolt as the ATF WS fluid drain/fill bolts, but don't guess.
    Maybe that panel could just be replaced, with a fresh drain bolt, if it comes to it.
    padroo likes this.
  11. VFerdman
    1,194
    1,218
    Bolt extractor (easy out) is trickier than it seems. They break very easily and make things more trouble than before. If not experienced with those, i suggest avoiding.
  12. padroo
    2,763
    2,252
    If the part it screws into is easily removable I disagree. If you break a bolt extractor you just remove the little pan.
    jerrymildred likes this.
  13. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    First thing I'd try would be a Torx bit socket that's just a little too big to fit in the hole.
    Pound it in with a hammer and use a ratchet or breaker bar to remove the plug. That will probably work, but if it doesn't, then I'd use a Dremel to cut a slot across plug head and use a cold chisel at an angle to make it move counter-clockwise rotation.
  14. Mendel Leisk
    41,873
    Belts and braces: hammer something in, like a torx bit, or a hex socket, then tack weld weld it in two or 3 places, before applying torque.
    Just guessing: maybe 3/8" (9.525 mm) allen key was used initially, in place of of 10 mm? Stanley for one makes a nice set of metric allen key "sockets".
  15. padroo
    2,763
    2,252
    This discussion reminds me of a day when I was at work and the guy I was working with wanted to do the job his way and I wanted to do it my way.
    He looked at me and said, "There is more than one way to get to ten", I looked at him kind of puzzled and then he continued. " 5+5=10.
    6+4=10, 9+1" . There are many ways for him to get that plug out now he will have to decide what works best for him.
  16. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    Vice grips - just be careful not to grip the case. Alternately tap it both ways, harder in the counter-clockwise rotation, until it loosens.
  17. padroo
    2,763
    2,252
    I couldn't tell how much was sticking up from the picture.
  18. Suprius
    29
    L.A, C.A
    Yes coolant drain plug for the inverter
  19. Mendel Leisk
    41,873
    I think if it comes to drilling through the drain bolt, I'd use the car as much as possible first, get a replacement bolt, replacement washer, coolant and whatever. Then to drain the inverter, take that whole panel off. That way you avoid getting drill shavings into the transaxle.
    When you're getting supplies, get the Toyota form-in-place gasket specd, assuming that's what's required.
    I've been looking through repair manual for info on that, so far no luck.
    You don't want to try wrenching those drain bolts with a regular length ratchet wrench: use extra long handle wrench, or impact driver.
    Robert Holt and tvpierce like this.
  20. Mendel Leisk
    41,873
    Too: having that plate loose, with the stuck drain bolt, you could run it over to a machine shop or garage, let them do the extraction, with all the knowhow and tools.
