  1. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    This is what I’m gonna be doing this weekend. Nothing special. I found out the dust covers were all in bits and start seeing a little leak. Since the car has 142k miles on it, I’ve gone ahead and ordered shocks for the rear as well.
    Raytheeagle, Burna J and James Powers like this.
  2. 04priusnow
    04priusnow Active Member
    345
    201
    I'm loving my new struts/shocks. Koni all around. I think mine have been toasted since I bought it with 90k on her. at 170k it drives like a new car. just need my sway bar.. next week I hope
    PH-1 ?
  3. MPGRaja
    MPGRaja Senior Member
    472
    1,681
    Corona
    Late night Lexus part pickup for the weekend project ;) just when you think you had enough
    My Inspirational
  4. orenji
    orenji Senior Member
    5,887
    3,488
    CT bottom engine cover? :)
    MPGRaja likes this.
  5. 04priusnow
    345
    201
    nice find! Not much left of my original. But not many Prius/Lexus parts in my area What year was it pulled from?
    PH-1 ?
  6. MPGRaja
    472
    1,681
    Corona
  7. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    Me too.
  8. Greenteapri
    330
    387
    Cypress
    This needs....a diffuser. Has anyone dabbled already?
  9. 04priusnow
    345
    201
    I thought all gen 3 came with that?
    PH-1 ?
  10. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    New sway bar links today. Heard a rattle on rough roads. This fixed it.
  11. 04priusnow
    345
    201
    I also replaced mine with the new struts. driverside had a tear in the boot. Interesting how the factory are aluminum.
    PH-1 ?
  12. D_H
    D_H Junior Member
    Seattle area
    Hello Dawit,
    I know you've sold your Prius but could you tell me where you purchase LED Ghost Shadow Lights w/ the Prius logo? The lights on Ebay & Amazon only have the Toyota logo. Also can you give me details on the logo for that glove box I'm thinking of doing something similar? Thanks.
    Burna J likes this.
  13. nick31
    nick31 Member
    65
    31
    SoFl
    Well it was a long day.
    I received bunch of parts from Japan, eBay and dealer. I spent most of Sunday installing them.
    I installed ct200h/RAV4 sway bar brace. It replaces 2 separated parts with a solid one.
    I replaced engine brace (it's a flimsy pipe) with a T-shaped part from Prius G.
    I replaced 2 triangle-shaped braces with the braces from Prius alpha-g. They have additional mounts for a stiffening plate which I also installed.
    I replaced bottom rear shock mount bolts/nuts with the revised bolts/nuts from frs/brz/ae86. Supposedly new bolts/nuts eliminate unwanted movement.
    All parts are genuine Toyota.
    And finally I changed the oil.
    I didn't take pictures, but here's one from internets to give you a general idea.
    #16973 nick31, Feb 3, 2019
  14. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    Good job doing your Homework!
    Did Two of the parts listed above and is quite an improvement!
    iPhone ?
    Dylan Doxey and HelloHybrid like this.
  15. WolfpackBill
    349
    500
    Lexington, NC
    Spent a few hours changing out the shocks and struts Saturday evening and Sunday morning. Total time spent was 4 hours and I took my sweet time. I spent a good 30 minutes taking out the cowl and rear quarter trims (2010 and 2011 models don’t have those plastic covers in the cargo area for access).
    PB Blaster is my new friend!!! That made working with nuts and bolts much easier. It was my first time using air tools as well. That was something I bought myself when my wife and I moved to our new house with a 3-car garage.
    I did not realize how bad the shocks were until I took them out. The car rides like when I first bought to car again.
    Before: 54D64B4B-48AB-4BC8-B55D-8B7EF6A53DAD.jpeg
    After: 0939EDEC-C3FD-40CE-B49E-5DC69A8B96B3.jpeg
    Dust boots in pieces: 25F8EBA0-9A64-4CD0-A1E3-03269D45C55F.jpeg F4358FC5-2DBB-44A2-8AB5-FAD890BB5FAA.jpeg
    One of the rear shocks compressed. I took this picture almost a minute after I compressed it. Pretty worn out. 24DD0E05-7AD1-47E8-AF74-94EF4E854807.jpeg
    sfv41901, Montgomery, Burna J and 5 others like this.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    I did our 2010’s about 6 months ago at around 180 k miles and they were in a similar state;).
    But for a set of shocks to go that long, is great:).
    No PB Blaster needed for the job out here though (y).
  17. WolfpackBill
    349
    500
    Lexington, NC
    So here's a question for you guys. Now that I have new shocks installed, what do I need to do to trash it? Can I just take it to the dump or do I need to take it to a parts store for recycling?
    Raytheeagle likes this.
  18. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    You’re supposed to drill a hole into the cylinder to allow the nitrogen out;).
    Then you can dispose of it in the normal trash:).
    The directions on how and where to drill the holes should be with the new shocks. But that’s what I did (y).
    Montgomery, WolfpackBill, RMB and 2 others like this.
  19. 04priusnow
    345
    201
    can you share part numbers for items not in photo? the Frs has struts in rear those bolts will work? also where did u buy these Japanese parts from? any decent links to research these items?
    PH-1 ?
    #16979 04priusnow, Feb 4, 2019
    Dylan Doxey likes this.
  20. nick31
    nick31 Member
    65
    31
    SoFl
    Jdm G parts came from akayama trading, turnaround time was 10 days.
    You can take a look at reviews/pics at minkara.carview.co.jp with Google translate, or just Google the part numbers.
    52255-76010 (jdm) is the same as 52255-0r020 so I got it used from eBay.
    Revised shock bolts are tad shorter but they still lock the whole nut. I got em from a dealer but only because my akayama order was already placed. I recommend getting them from akayama because it's cheaper. Part numbers are 2 of SU003-05235 and 2 of SU003-05213. There are some reviews at minkara as well, if you Google pn it will show some pics.
    Dylan Doxey, HelloHybrid and m3pare like this.
