TEIN FLEX A WITH EDFC ACTIVE PRO THOUGHTS
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 8404HMC, Jan 5, 2019.
  1. 8404HMC
    8404HMC Junior Member
    25
    31
    Martinez, CA
    I need to replace my struts all the way around on my 2014Toyota Prius 4 (68k). The tires vary any where between 1/2 an inch to 2 inches difference depending in the wheel.
    Anyone ever install TEIN FLEX A with the EDFC ACTIVE PRO? If so where did you put the EDFC? I am thinking about the dash to the right of the display.
    How did you like the set up?
    If no one tried this combination, any thoughts?
    Also going to install the TRD rear sway bar, Cusco or Tanabe strut tower brace, Cusco center brace and front brace.
    When I did this on my 2011 (no Teins but KYB struts with H&K springs, STB, RSB, Tanabe under brace). With the old combinations, it handled like a freakin sports car on the twisty roads... so much fun to drive... all though... MPG's tanked d/t my agressive driving! ;-)
    Thanks in advanve for all of your thoughts!
    Burna J and RMB like this.
  2. tweedle99
    tweedle99 Member
    125
    69
    Round Rock, TX
    Didn't even know tein made a kit for the prius.
    I had the same setup on my current 2010. I take them Fwy exchange at almost full speed. I get second looks from car, especially trucks that i passed. HAHA.
  3. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
  4. 8404HMC
    25
    31
    Martinez, CA
  5. Darthchoke
    Darthchoke Junior Member
    Los Angeles
    Did you ever install the tein flex A on your Prius l? how’s your experience with them compare vs lowering spring for daily driving
