Engine shakes after the motor start
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Noel Balo, Feb 4, 2019.
  1. Noel Balo
    Noel Balo New Member
    Riverside, California
    I just notice that my 2014 3rd gen Prius starts to shakes after I start engine. but will disappear less in a minute. any advice what is needed? Thanks
  2. xerox6135
    xerox6135 Member
    170
    94
    michigan
    Let start with how many miles is on your Prius. What maintenance have you done on your Prius. Do you have a check engine light.
  3. Noel Balo
    Its now 87,106 miles. no maintenance been done to it. im the original owner. no check engine.
  4. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    The dreaded engine knock
  5. Noel Balo
    so what causes it? thanks
  6. SB6
    SB6 Member
    324
    71
    Egr valve? I reported hearing engine rattle on cold starts to my dealership when I was there for some recalls, and they changed my egr valve I believe.
  7. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Welcome to the knock club, we’re always accepting new members :)
    Raytheeagle and bisco like this.
  8. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Never?! :eek:
  9. Austin Longenecker
    124
    66
    Austin Tx
    This has happened to my 2010 once after being left in the cold for several days with no use last yeat. Throttling the gas gently eliminated the problem. I've never seen it again. I live in Texas and drive almost every day, it almost never gets cold here so I've never seen that problem reoccur.
  10. Noel Balo
    yeah no maintenance been done to it yet!
  11. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    One approach to eliminating that knock is cleaning all parts of the EGR system, which tend to clog, and then installing an “oil catch can” to catch crankcase combustion vapors and condensates which may be causing the knock on start up.
    Grit likes this.
  12. Mendel Leisk
    41,317
    And clean out the intake manifold too, in conjunction with the Oil Catch Can install. It's on the receiving end of the PCV (Positive Crankcase Ventilation) circuit, and the EGR (Exhaust Gas Recirculation) circuit. The former will result in a oil/water/gas swimming pool directly below the throttle body, and the latter will clog up the EGR capilaries running through the intake manifold to each port, and carbon up the ports as well. Clean the throttle body while you're at it.
    Watch @NutzAboutBolts videos on all these subject, pinned at top of third gen maintenance forum.
    Some threads with info:
    EGR & Intake Manifold Clean Results | PriusChat
    Oil Catch Can, Eliminate that knock! | PriusChat
    Robert Holt and NutzAboutBolts like this.
  13. bisco
    51,840
    just don't start it and shut it down before the engine has finished the warm up cycle and shut down.
  14. Mendel Leisk
    41,317
    Next start-up after doing that, is the one time I got that knock, there seems to be a connection.
    I'll take advantage of the 15 seconds of EV the third gen has, if I need to move the car to the driveway, for example. I keep my moves to 10 seconds max, counting in my head. Shut down, repeat as needed. If I blow it, it starts up, I let it run till shuts off by itself.
    Never had a full brake inspection? Seems like a time-honoured American thing?
    Grit likes this.
  15. Noel Balo
    ok thank you everyone!
    Mendel Leisk and Raytheeagle like this.
  16. CR94
    CR94 Senior Member
    2,687
    1,166
    Northwestern S.C.
    That doesn't necessarily prevent the issue. I had not done that the one time mine exhibited the shaking routine upon start-up.
