Rear Wiper Aerodynamics
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jehan Ansar, Feb 9, 2019.
  1. Jehan Ansar
    Jehan Ansar Junior Member
    East Elmhurst NY
    Hello, This has been bothering me ever since I bought a prius last month. I like to know if the rear wiper affect the aerodynamics of the car. Would removing the rear wiper improve fuel efficiency and reduce drag score? I'm tempted to remove it so please let me know, thank you
    Burna J likes this.
  2. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    The short answer is yes, it would have to improve aerodynamics when you remove a bumpy thing like the rear wiper. How much improvement? Well, that's another matter altogether. It would also improve aerodynamics if you would apply smooth tape to the open joints around all your doors and find some very flat, plain wheel covers for all four wheels. Strictly speaking, not everything you can do to improve aerodynamics would be legal. You could also remove outside mirrors and front wipers, too. Don't forget to take down the radio antenna and remove the door handles. You will be climbing in and out of the car through the window like a racecar driver.
  3. ASRDogman
    ASRDogman Senior Member
    7,545
    3,895
    Of course, how would you get the door and windows open? :)
    You would have to install electronic door openers, which ads weight, which would probably cancel any savings. :)
    Don't forget sealing off the grill that catches all that wind.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    It would have to help, but the change would be so small I don't think you could tell the difference.
    Interestingly, Mythbusters once tried putting a dimpled surface on a car like a golf ball. They covered the car with clay and then cut out the dimples from the clay. Compared to the car with clay and no dimples (same weight), they saw quite an improvement in mpg at 65 mph. It went from 26.x to 29.x, I think.
    James Powers and Pluggo like this.
  5. Pluggo
    608
    533
    Just park with a window open, hopefully in a garage.
    James Powers likes this.
  6. ASRDogman
    7,545
    3,895
    That works, until you have to park somewhere else.
    You could trash the car so no one wants to steal it. :)
    #6 ASRDogman, Feb 10, 2019
  7. Mendel Leisk
    41,334
  8. padroo
    padroo Senior Member
    2,763
    2,252
    You will save more by keeping the tires properly inflated, not letting the car idle, consolidated trips to the warmest part of the day and avoid starts and stops, keeping the things you don't use in the car because of weight and the list goes on. If you never use your rear wiper it would be no big deal to remove it.
    One more thing, move to Florida where it is summer all the time and avoid those cold NY winters.
    jerrymildred and ASRDogman like this.
  9. Mendel Leisk
    41,334
    Gotta say I use the rear wiper about as much as the fog lights, and in the same spirit. Between the need to use it, and the way it swipes maybe 25% (if that) of the rear window glass, pretty useless.
    I could probably recoup more mpg by taking out the near 20 lb jump pack.
    padroo likes this.
  10. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    [This is a silly wild nice person guess, not based on research]
    I bet you would save more gas leaving the wiper but removing the wiper motor. It is pretty heavy. But neither one will amount to 1 MPG, so you would need very accurate equipment to prove me right or wrong.
  11. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    You can buy the OBD module that roll windows down when you unlock w/remote. Hop in through the window like bo and luke, then yell "yeeehaaaaw" as you floor it.
    Only block entire lower bottom grill if you have short drives or ICE stays off 70% of the time. The inverter & mg1 temp gets hot to dangerous temps at long hwy speeds, dr prius says so.
    James Powers and ASRDogman like this.
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Pull the rear bench seats out also. Soon as I can figure how to get the damn rear bench seats out, I'll do a real world mpg comparison and not post it on here.
  13. Mendel Leisk
    41,334
    I've got 100% grill block on lower grill right now. I go from 50% to 100% if and only if ambient temps are staying below freezing, and we're in a cold snap right now. Even so, if I was for example going up Mount Seymour, I'd STILL take it all out, regardless of ambient temp. From freezing to +10C I do just 50% lower grill block, and above 10 it all comes out.
    Inverter rad is behind upper grill on third gen, lower grill on second gen.
  14. orenji
    orenji Senior Member
    5,887
    3,488
    There are wiper delete kits available. If you look under modifications you will see ones that have been done.
    James Powers and Mendel Leisk like this.
  15. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    I removed mine. My reason wasn't about aerodynamics though. Mine was for looks. I literally never used mine but could see it out of my rear view which I hated... I did not see a gain in mileage.. At this point, unless you are trying to accomplish land speed records, it wont make a difference other than look better without it.
    jerrymildred likes this.
  16. padroo
    2,763
    2,252
    I have heard of people removing their front wipers because it looks better without it.
    The ones I am talking about live in very dry parts of the country and these cars are not daily drivers.
    scona and Burna J like this.
  17. Mendel Leisk
    41,334
    I heard in Russia there's a phenomena: it'll start to rain, and all the cars pull over, to install their wipers. They're a hot theft item, like the CAT's in London.
    orenji and scona like this.
  18. James Powers
    396
    555
    Bay Area
    Ive seen a few guys delete just one front but not both, thats just crazy lol
  19. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    I once saw a pirate driving a prius.
  20. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    The amount of fuel mileage you'll gain will be minimal removing the wiper. You'd gain far more with a grill block or pie plates over the wheels.
